flourescent effect
I built·a robot that included a ir emitter and sensor.· The robot worked perfect at my house but when I took it to work it behaved very sporadic.· I determined that it must be either the light sensors (the kind that when you walk into a room and the light automatically turns on) or the flourescent lighting or both.· Has anyone ever had this problem and if so can you explain what is going on and how to fix the problem, (ie, is there a type of sensor out there that is not effected by flourescent light).
I have not tried this 56 kHz module myself, but it looks just like the Waitrony 38 kHz modules I use regularly and are easy to connect to a Stamp.·However, I can't say for certain if the BS2 can send a 56 kHz pulse. I know the BS2's ability to output a 38 kHz pulse only works due to harmonics.·I'll defer to·tech gurus·Mike, Allan, Chris,·& PhiPi for comment here.
There is a similar item, the Hamamatsu S6986 for $4 at http://www.junun.org/MarkIII/Info.jsp?item=79·. Twice as good for twice the price? Only time will tell.
Worst case, assume the Stamp can't generate a 56 kHz signal. There is a very simple LM555 circuit on page 11/12 at·mil.ufl.edu/imdl/papers/IMDL_Report_Summer_04/siddiqui_salman/bob.pdf· that only uses a few parts. BTW, the part marked DEVICE is your IR LED. You could drive several IR LEDs (each with its own series resistor, start with ~ 100 ohms each) from one such 555 circuit. Just leave this circuit running continuously (low power draw) and now you've freed up a Stamp output pin to do something else.
f = 1 / ( 1.1 x R x C )
www.datasheetcatalog.org/datasheet/nationalsemiconductor/DS006975.PDF
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 11/3/2008 5:02:28 AM GMT
