4x20 Serial LCD with Keypad Interface Driver? (from Parallax)
So I have been looking for a driver object for this LCD and I cant seem to find one. If I have been staring at the obex for hours and its not there....... I have been having a heck of a time trying to make it work, and I am unable to decide if it is code error or something with the unit/my wiring.
Does anyone know if there is a driver for this LCD and where to download it?
It is the LCD from parallax.
www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/Level/a/ProductID/55/Default.aspx?SortField=ProductName%2cProductName
TJ
Post Edited By Moderator (Chris Savage (Parallax)) : 11/3/2008 5:57:43 PM GMT
TJ
as I took a short look into the manual
the "driver" will be as simple as
send bytes via a serial connection f.e. using FullDuplexSerial
this democode should almost work directly
''HelloFullDuplexSerial.spin ''Test message to HyperTerminal. CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ Debug: "FullDuplexSerial" PUB TestMessages ''HelloFullDuplexSerial.spin ''Test message to HyperTerminal. CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ Debug: "FullDuplexSerial" PUB TestMessages ''Send test messages and to HyperTerminal. Debug.start(31, 30, 0, 57600) repeat Debug.str(string("This is a test message!", 10, 13)) waitcnt(clkfreq + cnt)only things to change are
rx-pin (in the demo the 31 and tx-pin (in the democode the 30 and baudrate (57600 in the demo-code)
so as an example if your serial connection is on Propeller-IO-Pins 16 (rx) and 17 (tx) and the display has default baudrate is 19200
the command has to be changed to
Debug.start(16, 17, 0, 19200)
Does the display work with the demosoftware from the Matrix Orbital CD ?
as the manual says
2.1 DB-9 Connector
The LK204-25 provides a DB-9 Connector to readily interface with serial devices which use the EIA232
standard signal levels of §12V to §12V. It is also possible to communicate at TTL levels of 0 to +5V by
setting the Protocol Select Jumpers to TTL.
Did you do that ?
Maybe the 3.3V from the propeller might be too less if you connected the display DIRECTLY to Prop-IO-Pins
best regards
Stefan
You can use simpleserial object, or even write your own serial object with spin or asm as alternatives.·
When writing code, make sure that you have one cog running the LCD serial routine/method, and another cog running the keypad input.· This will ensure flicker-free LCD and a no-miss keypad scan.· It works quite nicely if you call cognew from a "main" or "start" style PUB block, to consecutively start the LCD·routine and the keypad scan.· That is unless you are really on a bare-bones power restriction.· This could be considered a "performance" protocol, and more cogs means more power.
what sleazy describes is the disadvntage of simple serial it can only send or receive sequential
it is NOT able of sending and receive at the SAME time
that's the reason why I NEVER use simple serial
I always use FullDuplexSerial
start FullDuplexSerial and the rest of receiving is done in the backround
you only have to take care of the buffer that you catch all received bytes
if more bytes are received as the buffersize the oldest bytes where just overwritten
if this doesn't matter read out the buffer when ever you want
best regards
Stefan
Post Edited (TJHJ) : 11/7/2008 2:14:36 AM GMT
''HelloFullDuplexSerial.spin '' Modified to pin 16,17 to test a 4 x20 parallax graphical display. ''Test message to 4x20 graphical display. CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ Debug: "FullDuplexSerial" PUB TestMessages ''Send test messages and to 4x20 graphical display Debug.start(16, 17, 0, 19200) repeat Debug.str(string("This is a test message!", 10, 13)) waitcnt(clkfreq + cnt)And the following attached image is what I get. What is strange is it is not a repeating sequence as far as I can tell.
Sorry its not the best picture, I couldnt find my camera, so I used my phone.
One other note, I am unable to use the test software provided, as for the parallax version of this does not include the db9 connector. And the jumpers are in ttl, I have not modified it in any way in an attempt to minimize how many things are changing.
mine looks like rev 2.x in this document.
www.parallax.com/Portals/0/Downloads/docs/prod/audiovis/LK204-25-Errata-V1.2.pdf
edit NOTE: I did perform a reset using the jumper method, as show in section 2.6 of the manual, So according to that it would in fact be in 19,2k bps, ttl level.
Thank you all again for looking at this, and helping.
TJ
Post Edited (TJHJ) : 11/1/2008 8:53:11 PM GMT
TJ
so where is the code ?
It also might be that it is a hardware problem
Did you test the Display with a terminalprogram on a PC ?
best regards
Stefan
Paul Baker
