Interfacing 433MHz Wireless RX/TX. Serout equivalent?
How would i go about interfacing the Parallax 433Mhz Receiver and Transmitter to the Prop?
Specifically the receiver.
Ive tried with BS2_Functions but i couldn't get it to work.
Any advice? Thanks.
Post Edited (FrameShift.) : 10/30/2008 11:11:15 PM GMT
Any advice? Thanks.
Paul Baker
Paul Baker
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
to state the obvious: the module needs a 5V powersupply.
the prop needs only 3.3V
As digitical data has only two states 0 and 1 = low and high
it should be quite easy to establish a connection that works properly.
If you receive data while the transmitter is not sending at all
there is something wrong with the electrical connection
@Parallax: The manual shows as small shematic where the rx/tx pin is connected to the IO-PIN
WITHOUT Pull-up/pull-down-resistor. Are there Pull-up/pull-down-resistors on the modul ?
(could you add this point to the revisionlist of the manual of the transceivers:
if it has internal pull up write explicit about it
if it has not add a shematic showing how this can be done)
best regards
Stefan
This is what I was trying to explain in my previous post.· If you start by transmitting a header of several $F0 bytes, the receiver can lock on and align to the start bits of the signal.
- Bjarne Stroustrup
Post Edited (Ken Peterson) : 11/3/2008 1:53:04 PM GMT
Paul Baker
Getting them to switch roles to have a full duplax conversation is another thing entirely.
Watch your delays between changing from recieve to transmit mode and back. The Linx products I use have significant delays to switch in and out of the T or R mode. The transmitter also powers up with a signal pulse output that your reciever needs to be able to digest. Read those spec sheets on the RF products very closely.
You also need to look out for test proximity and ambient noise. If your transmitter is too close to the receiver at very high speeds you can 'saturate' the reciever. For noise I took an extra receiver and wired it to my scope as sort of a background monitor just to see what the ambient noise was before running tests.
Finally, if your reciever has an adjustable squelch or you can modulate the transmitter power, make sure you have not accidently turned those up too high by not putting in a resistor somewhere.
Good luck,
Jim-
Signature space for rent, only $1.
Send cash and signature to CannibalRobotics.
