Sure Electronics 64x32 LED Matrix... — Parallax Forums
BamseBamse Posts: 561
edited 2013-06-28 08:41 in Propeller 1
Here is the start of a Propeller driver for the LED matrix from Sure Electronics.
This was a little bit tricky to get working since the data sheet is not the best...
However after reading the thread for the SX48 driver I managed to make sense of the whole thing... wink.gif
The Matrix have been bit mapped for easy use and the driver runs in a separate cog...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
  • tpw_mantpw_man Posts: 276
    edited 2008-10-14 00:36
    Nice! I have always wanted to get a nice large matrix and toy with it. How much does it cost?
    I am 1011, so be surprised!
    Advertisement sponsored by dfletch:
    Come and join us on the Propeller IRC channel for fast and easy help!
    Channel: #propeller
    Server: irc.freenode.net or freenode.net
    If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
  • BamseBamse Posts: 561
    edited 2008-10-14 00:54
    About $50 including shipping if you order from their web-site...
    However the SX thread suggest that you can get it cheaper from E-bay...
    http://forums.parallax.com/forums/default.aspx?f=21&m=282223
    My display had one dead Green LED though, if you look closely at the R in GREEN you might be able to spot it...
    Experience level:
    /Bamse
  • T&E EngineerT&E Engineer Posts: 1,396
    edited 2008-10-14 00:55
    I'm glad to see the work put in by PJ Allen and myself is being expanded on. Be sure to look in Nuts and Volts magazine in the next few months for an article I wrote about the display and applications (as explained in the link below).
    BTW: Here is the link to the SX48 / 28 versions that·Bamse mentioned: http://forums.parallax.com/showthread.php?p=746212
    You can get them on Ebay for about $58 with free shipping: http://cgi.ebay.com/6432-Dot-Matrix-3mm-Bicolor-LED-Info-Board-Demo-Board_W0QQitemZ250305636655QQihZ015QQcategoryZ26206QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    or at the Sure Electronics site for $37 + $21 shipping from China. I have ordered many of them and they have great products!
    http://www.sureelectronics.net/
    edited 2008-10-14 01:09
    I paid $35.99 for the board and $13.71 for shipping...
    Totally $49.70...
    I decided not to get the demo board, maybe that saved me on the shipping...
    Experience level:
    /Bamse
    edited 2008-10-16 06:06
    Experience level:
    /Bamse
    1600 x 1200 - 622K
    edited 2008-10-16 18:05
    Cool! But do not get too far! I want to have something to work on!
    Channel: #propeller
    edited 2008-10-17 05:29
    I want to make a PONG game...
    I got the MCP3008 hooked up and the Commodore Paddles connected...
    However it looks like the pots in the paddles are logarithmic so I need to figure out how to convert it to a linear scale...
    I basically need to convert a logarithmic value of 0-1024 to a linear value between 0-1024 using Spin and integer.
    Experience level:
    /Bamse
    edited 2008-10-30 03:10
    Still just goofing around...
    Experience level:
    /Bamse
    Post Edited (Bamse) : 10/30/2008 3:16:14 PM GMT
    edited 2008-10-30 11:40
    I have been able to cascade (2) 6432 displays together thanks to PJ Allens work - on an SX28 chip. However, the routine required moving from a 20 MHz resonator to a 50 MHz resonator due to the scanning routine used most likely.
    1600 x 1200 - 1M
    edited 2008-10-30 15:15
    That is Sweet, I like your font, a lot cleaner than the C=64 font I'm using....
    By the way, I updated my previous post and added the code...
    It was late, sorry I forgot to attach the code...
    Experience level:
    /Bamse
  • tdg8934tdg8934 Posts: 126
    edited 2013-06-27 12:18
    Take a look at this link: http://forums.parallax.com/showthread.php/148742-Sure-Electronics-6432-board-equivalent-by-Embedded-Adventures-in-UK?p=1191936#post1191936
    This looks like an equivalent to the Sure Electronics 6432 obsolete board with some very minor changes.
    Tim
  • tomcrawfordtomcrawford Posts: 1,129
    Here is a video of three 16 x 32 boards. I treated the display as a dumb frame buffer, 96 x 16 x 2 = 3072 bits. I just re-write the entire thing each time I put up a new column. I used machine language in a dedicated cog.
    http://www.youtube.com/watch?v=T8FWoQeLcO0
