RealRandom number between 0 and x
The RealRandom object is great, but it doesn't give random numbers between 0 and x (to be specified).
This doesn't work:
Because it gives numbers that are always near x/2.
This doesn't work:
Because of the divisions the random numbers don't reach x.
Any idea's how to get this working?
Kind regards,
Robot Freak
Post Edited (Robot Freak) : 10/28/2008 4:28:23 PM GMT
This doesn't work:
repeat x random += rr.random & 1
This doesn't work:
x /= 2 repeat while x <> 0 temp := rr.random & 1 if(temp == 1) random += x x /= 2
Kind regards,
Robot Freak
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I tried this:
Most of the times it returns zero, sometimes -649142272 or 605822208.
So it isn't working jet, do you know what is wrong in this code?
Thanks for your help,
Robot Freak
Post Edited (Robot Freak) : 10/28/2008 8:11:57 PM GMT
An easier way might be to use the technique used with the gcc compiler and use something like rand()%(N+1), where rand() returns a value between zero and RAND_MAX.
Leon
Post Edited (Leon) : 10/28/2008 8:31:40 PM GMT
Here is a slight modification to the "RealRandom Demo" that should do what you want...
I added "PUB Random(N)" where N is the maximum random number minus one returned.
Beau Schwabe
IC Layout Engineer
Otherwise there's a 1 in 65536 chance that Result = N.
Ohh I See.... Ok, just leave it the way it is and the number produced is between 0 and N .... NOT 0 to N-1
Beau Schwabe
IC Layout Engineer
Doing what I suggest gives a uniform distribution of the numbers from 0 to N-1 (assuming RealRandom is uniform, of course).
Beau Schwabe
IC Layout Engineer
