Usb Keyboard driver — Parallax Forums
Usb Keyboard driver
PashaPasha Posts: 56
edited 2008-10-27 22:34 in Propeller 1
Hello, I have the PropRPM board, which has video, but no keyboard or mouse control options. I do not have a ps/2 head lying around, so i would like to build a driver that uses usb, which could be connected simply by using a usb extender cable which can be bought for only a dollar. I think it aught to work, but I can't find the usb protocol anywhere. Can anyone help me.
PS. I know that usb is 5V, but i am using a 5V power supply, so i can take the voltage from there.
  • OwenSOwenS Posts: 173
    edited 2008-10-25 09:51
    The Propeller can just barely do USB slave (and in doing so it violates the specifications).
    It is simply incapable of being a USB host, however. That is more difficult.
    The best way to use a USB keyboard would probably be a FTDI Vinculum. I beleive that they can emulate a PS/2 keyboard, but I don't know how to configure them to do so
  • AleAle Posts: 2,363
    edited 2008-10-25 10:31
    No no no. I do not agree. There are several examples of AVR devices being hosts to mice and keyboards. The point is that they barely understand the protocol, they are fixed function and pick the data from the stream without decoding packets and so on. It is a matter of translating this to propeller assembler and using a suitable level shifter.
  • heaterheater Posts: 3,370
    edited 2008-10-25 10:50
    For a "gentle" introduction to the USB hardware and protocol see here www.beyondlogic.org/usbnutshell/usb1.htm
    You'll see why I put "gentle" in quotes when you get there. All that to connect a keyboard or mouse, insane !
    And by the way why do they call it a "bus" when it only handles point to point connections without the help of a hub?
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2008-10-25 12:59
    WATCH THAT 5 VOLTS! There was a prop incinerated a couple of days ago with the play by play right on the forum.
    On as my wife would say, "3.3" it's the new 5.0!
    Jim-
    A wise man told me; "All electronics are made to work by magic smoke.
    Don't ever let it out as it's·very difficult·to get it back in."
  • hippyhippy Posts: 1,981
    edited 2008-10-25 13:10
    @ Ale : Do you have any links or search hints to AVR/PIC/other projects implementing bit-banged USB Host firmware ? All the searching I tried was swamped with USB Slave solutions ( notably AVR-USB ).
    @ heater : USB is quite complex, but then it does a lot and serves multiple purposes. How "insane" depends on how you look at it; whether designed and over complicated to connect a keyboard or mouse or designed as a communication technology and then used for keyboard and mouse. "Bus" I think is valid as it's a common and generic term used to describe any inter-connection over which information is passed.
    It seems to me that USB is quite complicated, needing a good understanding of all the protocol layers and the general overview, with a hardware level protocol which pushes a processor to its maximum. That needs quite a skill set and understanding which is perhaps why (AFAIK) only BradC has delivered anything for USB and no one seems to have taken his work any further.
    I expect those who want to use USB, simply want it, don't appreciate the complexity nor have the skills to implement it themselves. Few have the skills to do USB and those who could have other projects or don't have the time to commit. It does look like quite an uphill struggle for anyone who has only minimal knowledge of USB.
    Maybe we need a 'working group' and some 'USB Champion' who could push development of Propeller USB forward ? "A problem shared ...", as the adage goes.
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2008-10-25 13:22
    A person could check out using the usb boot protocol which is a bit easier I think.
    Usb powers at 5.0v and the signals are at 3.3v.
    Usb is not easy and if it is just a matter of not having the connectors, I am afraid you will spend more time and money than it is worth getting this to work.
  • BradCBradC Posts: 2,601
    edited 2008-10-25 13:52
    The USB boot protocol would likely be doable at a clock speed of 96Mhz. You _need_ precisely that clock speed as USB host must be incredibly accurate with its timing. There would be a not-inconsiderable amount of work implementing the protocol handling aspects and you'd not be able to comply with the timing requirements if you implemented the required level of CRC checking. Not to say it can't be done however, just that the amount of effort and memory consumed would well outweigh the cost of mail-ordering a solid gold PS2 keyboard from halfway around the globe.
    I've been meaning to pick the USB stack back up. I have a completely universal HID implementation now that is usable for keyboard/mouse/joystick and general HID traffic (it also works as a debugger/bootloader using 2 cogs), but I've been kinda sidetracked the last couple of months with some other projects.
    Pull my finger!
  • AribaAriba Posts: 2,694
    edited 2008-10-25 14:37
    BradC
    Why is the bit timing for a Host more critical than that of a Slave? Both receive, or send an USB packet, timed by it's own, without a sync clock or something similar from the host. Is it not easier to implement a host, because you can decide when you will send a packet, and then you have a lot of time to decode the respond, until you start the next request?
    What I don't know: Are all mice and keyboards Low Speed devices, or in other words: Is Low Speed a part of the HID spec for mouse and keyboard?
    Andy
    edited 2008-10-25 15:16
    Ariba said...
    BradC
    Because the USB spec says so. Hosts must be incredibly accurate, while low speed devices are allowed +/- 1.5%, a host/hub of any kind is 0.05% (USB2 spec clause 7.1.11)
    Ariba said...
    No. There are strict timing requirements that a device must expect from the host. If the host violates those timings then the device state may well be indeterminate.
    Ariba said...
    No, a HID device may be any speed from low to high. Most keyboards and mice I've seen that are single function devices are low speed, but there are certainly no guarantees.
    Pull my finger!
    edited 2008-10-25 15:44
    Now I do not find it :-(, but I have a link at work.
    I saw the implementation of a USB to PS/2 adapter or something like that with an atmega8 or 32. I thought it was some work but straightforward to reproduce. I'll post the code I downloaded if I do not find the link.
    There was a thread about this in mikrocontroller.net
  • ForrestForrest Posts: 1,341
    edited 2008-10-25 16:08
    You can build a PS/2 keyboard interface with a PS/2 connector and 4 resistors. You'll also need +5V to run a PS/2 keyboard. PS/2 keyboards are very inexpensive - geeks.com has some for less than $3. I walked into a Microcenter a few weeks ago and bought a 108 key Inland PS/2 keyboard for $3.99.
    edited 2008-10-25 19:15
    @ Ale : Thanks for that. It at least got me to ...
    instruct1.cit.cornell.edu/courses/ee476/FinalProjects/s2007/blh36_cdl28_dct23/blh36_cdl28_dct23/index.html#software
    "SIAM32 USB HC
    Software Implemented Atmel Mega32 Universal Serial Bus Host Controller"
    edited 2008-10-25 20:16
    BradC, thank you for the detailed answer.
    I think, it's only possible to implement a low speed host for mouse and/or keyboards, which is not defined by any USB specs.
    A full USB host has certainly much higher demands.
    If a host driver is made for only a mouse, then you don't need to request all the descriptors. Just give the mouse an address ("Enumeration light") and request the data packets for X,Y and buttons. To keep the mouse alive a EOP (End of packet) is needed all 1 .. 3 ms. IMHO this should be doable.
    Today such a driver is not really necessary, because one can still buy PS2 devices. But new computers have no PS2 ports, and some day only USB devices will be available.
    Andy
    edited 2008-10-25 22:12
    One advantage would be two pins for both keyboard and mouse (if possible)
    Actually, is there such a thing as a "low speed" usb serial adapter? it would be wonderful if it was possible to get rid of the usb<->serial chips... and there may be enough time for Chip to add such a usb-serial driver to the rom in Prop2....
    Ariba said...
    Andy
    www.mikronauts.com - a new blog about microcontrollers
    edited 2008-10-26 01:50
    Bill Henning said...
    Not a hope I'm afraid. Hub enumeration is _way_ out of the question.
    No, not really. All usb-serial adaptors use bulk endpoints, and bulk on low-speed violates the spec. It won't even work on linux without patching the kernel.
    Having said that, the cdc-acm driver floating about in the forums _does_ work. I've been using it to have my thermostat communicate with my server now for months without issue (but I had to patch the kernel to allow it).
    Pull my finger!
  • PashaPasha Posts: 56
    edited 2008-10-26 07:12
    Thanks for all the detailed answers this is exactly what i needed to know. I still think it would be great to work on it especially as a group, even though it is hard. I still don't quite understand how it all works, but I am still reading.
    edited 2008-10-26 08:47
    @Hippy : I can quite accept the complexity of a general solution to connecting gadgets, especially as the low level bit twiddling is intended to be handled by silicon not software. I just can't help thinking it got "over complicated" somewhere along the line.
    Calling it a "bus" still grates with me. Old electric "bus bars" were called that because they distributed power to many points. Later the term bus was applied to address and data buses which again had many devices attached. In networking "bus topology" is defined as many nodes connected to a central cable. So "bus" just does not seem correct for USB.
    Bah - I'm becoming a pedantic old man.
    edited 2008-10-26 10:50
    I agree with BradC, that 2 pins is very difficult. Perhaps it's possible with 3 pins: 1 shared D+, and 2 separate D- lines.
    The only low speed USB-to-Serial "chip" I know, is the AVR software solution from:
    www.recursion.jp/avrcdc/
    That the needed low speed bulk transfer is not specified, is not the main problem, because if one makes a host driver, he can decide what is implemented.
    But I don't see the advantage to use a USB Bridge for a serial communication. The propeller can handle many Serial Ports direct, and if the pin count is the problem, an I2C-to-serial solution would be easier and faster (needs also a custom programmed Controller).
    I hope the Prop2 will be able to support full speed USB, either with bit-banging, or with an appropriate Input-shifter hardware.
    Andy
    edited 2008-10-26 12:01
    Ariba said...
    The advantage in my case is I have 3 pins on the propeller + 3 resistors and I can plug into a USB port on Windows/MacOS/Linux and pretend to be a serial port.
    Linux still needs a 2 line kernel patch, and Windows needs an .inf file however. But certainly no external USB-Serial hardware required.
    With the USB HID bootloader, no driver/.inf files on Windows required, Linux is just plug and go and MacOS requires the installation of LibUSB (I'm trying to work around this however).
    So you can just plug and go on almost any OS.
    For RS232 you require (well, kinda) level shifting hardware and 2 prop pins
    For USB-Serial you require a USB-Serial converter + level shifting hardware (or a propplug/clip) and 2 prop pins
    For USB direct you require 3 resistors and 3 prop pins.
    I see an advantage [noparse];)[/noparse]
    Pull my finger!
    edited 2008-10-26 14:06
    BradC
    We speak not from the same thing. Yes I see certainly an advantage, for a propeller slave to use CDC and emulate a serial port.
    But Bill has asked for a propeller host, that supports connected USB to serial chips (ie. FTDI). And for that I don't see an advantage, regardless of that it's not possible with an FTDI.
    Andy
    edited 2008-10-26 14:19
    Ariba said...
    Andy
    I apologize, I understood Bill to be suggesting the Prop come with a USB bootloader rather than talking to a USB-Serial converter.
    I'm with you on that one.
    Pull my finger!
    edited 2008-10-26 17:30
    Hi Ariba,
    That's not quite correct, what I was looking for is something like what Brad has... I was trying to eliminate an FTDI smile.gif
    Best Regards,
    Bill
    Ariba said...
    BradC
    Andy
    edited 2008-10-26 17:31
    No Brad, you were correct [noparse]:)[/noparse]
    BradC said...
    Ariba said...
    Andy
    edited 2008-10-26 21:21
    OK, sorry Bill. I don't have understood the words "get rid of" correctly.
    So you mean a "low speed usb serial adapter" in software inside the propeller for communication with a PC?
    This must be an USB slave then, and BradC has already done this.
    http://forums.parallax.com/showthread.php?p=675351
    Andy
    edited 2008-10-27 00:29
    No problem [noparse]:)[/noparse]
    I'll have to check it out - sounds great. I am hoping Chip will use something like it for Prop II
    Best,
    Bill
    Ariba said...
    Andy
    edited 2008-10-27 09:54
    Here are the promised links:
    http://www.asahi-net.or.jp/~qx5k-iskw/robot/usbhost.html
    http://www.mikrocontroller.net/topic/30029
    Ale
    edited 2008-10-27 12:15
    Nice links, thanks! Google does a barely manageable translation of that page. The code is fairly easy to understand though.
    Everything is hard coded, no error checking of any kind is done and the returned data is not really parsed, but it's still a big achievement. There are hard coded areas for each device as while they are all USB compliant, each one responds slightly differently and without actually processing the returned data properly it's hard to know what the device is expecting.
    Using 2 or 3 cogs, it's probably possible to do a passably better job with a propeller, but then you start to run into the kind of compatibility problems the author did with regard to different devices responding with different timing and parameters.
    Pull my finger!
    edited 2008-10-27 13:27
    Wait a minute BradC. Is it really so that we need up to three 32 bit processors running at 20 MIPS to do what one dinky little 8 bit micro can do with whatever MIPS it gets from it's 12MHz crystal?
    If so there is either something very wrong with the Prop architecture or it's programming languages/environment. I find that disturbing. To connect a keyboard and a mouse I've just consumed most of my wonderful Propeller. Would not be worth it.
    Now I know almost nothing about USB except that it takes: 1) Some very slick bit banging assembler level code if you want to do the lowest hardware level in software, which we do. 2) A big pile of less slick code, in preferably some higher level language to handle the higher protocol levels.
    That much I can discern from looking at the AVR-USB code. www.obdev.at/products/avrusb/index.html
    Now looking at the Prop, we see that the bit banging assembler is quite possible, as your USB stack demonstrates, and that there is probably quite enough room for the higher level slower code. Problem is we can't do both from a single COG at the same time, in SPIN at least.
    So to get around this don't we need to use LMM ?
    Do the bit banging in neat assembler which then jumps into the LMM kernel to run the higher level code when required.
    This would require being able to fit the USB bit banging code and a small LMM kernel into a single COG. The LMM code can take as much space as it needs from HUB RAM.
    In my small way I have resorted to doing this with my 8080 emulator. Most 8080 instructions are interpreted by neat assembler but, as I ran out of COG space, a few less used ones are farmed out to LMM code. The LMM kernel is tiny.
    I have not really looked at the ImageCraft LMM kernel for C, I suspect they have not left enough room for any more code in the kernel. Perhaps it can be stripped down, I don't know.
    Or we need a much simpler high level language that will run with a very small LLM kernel. Or just an LMM assembler.
    What do you think?
    edited 2008-10-27 13:39
    heater said...
    No, no, no.. if you want to perform the hack they are doing with the AVR, then sure you can probably do it in one cog. You just won't get the functionality you are actually after (and certainly not the reliability of being able to plug any old USB mouse or keyboard into it and having it work)
    If you want to do it _properly_ you will need some more horsepower.
    By properly, I mean at least with some very basic error checking and parsing enough information to be able to make use of more than one particular make/model of device.
    Pull my finger!
    edited 2008-10-27 13:44
    heater, what Bard pointed out should not be overlooked: That code barely gets the data out of the stream! Of course an AVR at 12 MIPS cannot do more than a prop at 20! (with exceptions, few) The prop can be overclocked to 96 so you have a multiple of the bit freq, and with maybe 2 COGS a better job can be done, a bit more of the protocol understood and maybe more compatibility brought into the equation. If you look at the code the "host" AVR send preformatted frames that are in ROM (Flash)!
