Correcting Power Factor of fluorescent lamps
Let's say I have a typical 36w 4 feet fluorescent light that uses 240v AC.
We all know that the coil ballast will skew the power factor one way which is not desirable.
Should I connect a X2 class capacitor across the power input lines (just before going into the lamp) to reduce the skew?
What should the capacitance value be? Will the correction be worth it?
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
36watt bulb no worries. Everything in your house for the most part sucks at PF. Most SMPS have a PF of .6 to .4. Shaded pole induction motors again .6 to .4
Leon
But I do know that if the PF for one 36w lamp can be corrected to 1 (or close to 1) using a built in capacitor,
it will be useful when many such corrected lamps are installed at one location.
Therefore, I am still interested to find out the optimum capacitance value for 1 lamp and whether the capacitor and coil ballast will oscillate as a LC pair.
www.fd.com.my
www.mercedes.com.my
Post Edited (william chan) : 10/24/2008 5:21:33 PM GMT
Leon
Here are a couple of links that might help explain PFC
www1.eere.energy.gov/industry/bestpractices/pdfs/mc60405.pdf
www.allaboutcircuits.com/vol_2/chpt_11/4.html
Beau Schwabe
IC Layout Engineer
