Stupid Question needs answer!!!
Hello , can someone answer to my question , in the example 1 :
PUB Toggle
dira[noparse][[/noparse]16]~~
repeat
!outa[noparse][[/noparse]16]
waitcnt(3_000_000 + cnt)
it runs the internal fast clock about 12MHz , is this means that on the output Pin 16 we will have a frequency of 12MHz ?
PUB Toggle
repeat
Rember the speed is how fast per second. So your clock counter runs increments 12_000_000 per second. and the waitcnt command, waits for that number to increase xxxx amount. In this case 3_000_000. So it changes the state of the pin every 1/4 of a second. 12_000_000/3_000_000 = 4.
Hope this helps.
TJ
edit. The above assumes the world is perfect. And does not account for command time.
EDIT********* SEE WHAT BEAU SAYS BELOW. He knows way more than me. ************
Post Edited (TJHJ) : 10/24/2008 5:28:18 PM GMT
With the waitcnt instruction in place it will toggle P16 at about 2Hz. With the waitcnt instruction removed it will toggle P16 at about 6.8kHz
The 'repeat' plus '!outa[noparse][[/noparse]16]' takes 880 system clocks to execute in Propeller Spin... at 12MHz that's 83.3333ns times 880 clocks or 73.3333us.
Toggling a pin every 73.3333us equates to 6.8kHz
If this were written in Propeller assembly running at 12MHz, then it would toggle the pin at about 750kHz because it would only require 8 system clocks.·· ...at 12MHz that's 83.3333ns times 8 clocks or 666.6666ns.
Toggling a pin every 666.6666ns equates to 750kHz
[b]CON[/b] IOPIN = 16 [b]PUB[/b] Main_TOGGLE_Demo AsmToggle 'SpinToggle [b]PUB[/b] AsmToggle [b]cognew[/b](@AsmTogg1e,0) [b]PUB[/b] SpinToggle [b]dira[/b][noparse][[/noparse]­IOPIN]~~ [b]repeat[/b] ![b]outa[/b][noparse][[/noparse]­IOPIN] 'waitcnt(3_000_000 + cnt) [b]DAT[/b] AsmTogg1e [b]org[/b] [b]mov[/b] [b]dira[/b], PinMask Loop [b]xor[/b] [b]outa[/b], PinMask [b]jmp[/b] #Loop PinMask [b]long[/b] 1 << IOPINNote:
Keep in mind that using the internal 12MHz clock is not a very·accurate time base.· In my tests my measured results ran about 11% faster which means that my 12MHz clock was actually running closer to 13.3MHz
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 10/24/2008 4:48:36 PM GMT
toggle a pin, then toggle it back, measure the pulse width and record it's value.
place the instruction to be timed in between the two toggles, measure the new pulse width.
subtract the first value from the second value and that's how long the instruction took to execute.
Paul Baker
How did you measure the REPEAT?
Paul is correct!
As for measuring the REPEAT, I didn't... the 880 is a combined number that represents both the REPEAT and the OUTA command.
If I wanted to measure the REPEAT, then I could do it by deduction... adding another OUTA command to another pin as a "filler" command.
By noting how much delay was added by the additional OUTA, I could subtract that same amount of time from my original 880 clocks to determine the amount of time that REPEAT takes to execute.
Beau Schwabe
IC Layout Engineer
Beau Schwabe
IC Layout Engineer
