basic stamp in a auto feeder
I am building a auto feeder for my horse·who is in a pasture with other horses. I am wanting to use the basic stamp for this. I need the basic stamp to run my program only when my horse gets close to the feeder. I was looking for something like a·rf receiver/transmitter. Something that tells the program to run when·my horse sticks it's head in. Any ideas on what will work with the basic stamp that draws low power that would be cheap to build.
Like this.
receiver gets signal
runs servo for pre-determind amount of time
pause for· 30 min.
loops waits until signal returns then starts over.
I am a newbee so I want to keep it simple to start off.
Like this.
pause for· 30 min.
ISO Card: 6.3cm (2.5") +/- 10%
World Tag 50mm: 6.8cm (2.7") +/- 10%
World Tag 30mm: 5.3cm (2.1") +/- 10%
Bobsleigh Keyfob: 5.3cm (2.1") +/- 10%
Tear shape: 4.0cm (1.6") +/- 10%
Wristband: 4.0cm (1.6") +/- 10%
This might present a big problem (though I'll bet that·horses are smart enough to learn how to get the tag near the reader if there's a food reward involved, provided things are mounted appropriately).
However, you could make an infrared "Beacon" that sends out a code, and a base station at the trough that reads this and opens it. In daylight, an unshielded IR should get at least a couple of feet, but not a fields length.
I have looked for doc. on the internet about the cat/dog door without any luck finding any info.
and I am not sure it would do what I need I dont really need a door to unlock I need a wheel to turn at a slow speed for a amount of time that is adjustable.
Note that you could send out the 38kHz signal to the IRLED with a BS2, but that is complete overkill even to the point of detracting from the setup. So, if you decide to go this route just look around. There's a relatively simple setup with a timer chip of some sort that you can use.
The rest of it you can do with a BS2. There is a chapter in the RwBOEBOT book about IR. Just read on that and you'll see how simple it really is.
With that in mind, why not try to make something that works similar to an active RFID setup? Have a sensor of some sort to detect a horse at the feeder. If that sensor is tripped, then the RF part of the circuit is enabled that verifies the horse AT the feeder transmitting from an RF beacon (or IR beacon). De-tune the antenna on the horse's transmitter limit the range so that your horse must be AT the feeder, not next to another horse trying to steal some food.
Just saw something else on eBay that might be something you can hack or use as an idea starter... cgi.ebay.com/Handbag-Purse-Anti-Loss-Theft-Transmitter-Alarm-Finder_W0QQitemZ230302695980QQihZ013QQcategoryZ115946QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
~~ dRu ~~
Post Edited (dRudRudRu) : 10/24/2008 11:38:18 PM GMT
A passive IR option which might work is to put reflective material on your horse's bridle. When he sticks his head into the darkened box, an internal IR sensor looks for reflected IR from an internal IR LED. Might take some calibration under various lighting conditions. Instead of a 38 kHz pulsing system, consider a DC light level system. I've had good results in varying light conditions by using a plain old IR phototransistor like a photocell in an RCTIME configuration. Keep sampling the ambient light, which slowly changes during the day, but when the reflective material is seen, it spikes up the reading (relatively) from whatever the ambient reading is.
But overall, RF is a better bet here. No IR or light worries, just a weak (short range) radio transmitter pulsing every few seconds. You will need to monitor the transmitter battery to know when to replace it.
IR would work fine even in daylight at shorter ranges <5ft, but you would be changing batteries all the time
Another possibility might be a load cell,·same idea, the wieght of the horse activates the load cell and signals the Stamp.· Mounting the load cell would probably require modifying the floor though....
The only problem I can foresee is detecting your horse as opposed to any horse.· Maybe a layered system, where the pressure mat/load cell signals the Stamp, which can use a second system·(IR???) to positively ID the horse.· With the mat, you have an idea where and how close the horse is.
Anyway, food for thought.· I hope·it helps.
"to run my program only when my horse gets close to the feeder."
Why not just barcode your horse? Cut the hair in a certain pattern so that skin shows through, then read the stripes? [noparse]:)[/noparse]
Range: 0 - 25 meters/0 - 82 feet (without hindrance)
Transmitter power: X1 3V CR2032 button battery
Receiver power: X1 1.5V AAA battery
Transmitter battery life: 3 weeks
Receiver battery life: 2 months
Transmitter dimensions: 4 x 2.8 x 0.9cm (1.6 x 1 x 0.3")
Receiver dimensions: 6 x 3.6 x 1.5cm (2.4 x 1.4 x 0.6")
Will have to find a way to interface it with the stamp and try to ext. batter life the unit can be bigger than it is so adding a AA battery might be my best bet. If I can get like one week out of a AA that would be great but I think it will work .. Thanks dRudRudRu and everyone else. When I get the alarm I am sure I will have a few quistens.
power reduced or something to limit its range?
Maybe a combo of Ping to check distance, and PIR to check for heat?
Having electronics on the horse is a bit of an overkill... and batteries would be an issue.
If the issue is checking to see if its YOUR horse only... maybe RFID is an option... perhaps something
like a bracelet around its ankle and a reader it has to walk past?
http://www.linxtechnologies.com/Products/Integrated-Circuits/
Jim-
Signature space for rent, only $1.
Send cash and signature to CannibalRobotics.
Is your horse shod? You could have your farrier install a magnetized foreshoe, or one with a magnet in it anyway. It would have to be specially made, because horseshoes are usuallly soft iron that doesn't retain magnetism very well.
Then build a strong pad with one or more reed switches in it. When your horse stepped on the pad, the magnet would close a reed and the feeder would start. No other horse would have a magnet, so only your horse could run the feeder. It shouldn't be difficult to train the horse how to start the feeder by stepping on the pad -- animals have been trained to do much more complex things than that, with food as the reward.
· -- Carl, nn5i
