Power for a minimal prop board?
Oldbitcollector (Jeff)
I'm putting together a minimal Propeller setup and am curious if
just feeding the Propeller current from a 7805 (+5 regulator) thru a
10K resistor (to bring it down to 3v) would sounds like it would
provide safe/decent power for the Propeller chip?
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
OBC
Paul Baker
Post Edited (Paul Baker (Parallax)) : 10/24/2008 5:33:08 PM GMT
OBC
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
and I'm trying to keep this board very minimal. [noparse];)[/noparse]
I'm curious about the mention of using diodes? Can you elaborate?
(Sorry, I'm just not an EE. )
An LED/resistor might serve dual purpose of power indication as well as reducer?
OBC
Post Edited (Oldbitcollector) : 10/24/2008 5:52:55 PM GMT
Paul Baker
The LM317 plus resistors is cheaper than a 3.3V fixed regulator, and can give better performance.
Leon
Paul Baker
Post Edited (Paul Baker (Parallax)) : 10/24/2008 5:59:22 PM GMT
I notice on the ProtoBoard, there seems to be no Diode to protect against possible damage if a Negative center wall wort is plugged in accidentally. Do the regulators have some built in protection in this regard? I'm designing a new version of SpinStudio, and if that diode is really not necessary, it'd be best to go without.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Addendum: DigiKey carries the Microchip MCP1700-3302E/TO for $.53/1. This is in a TO-92 package and specs up to 250mA output current. I requires only a 1uF ceramic filter cap for stability.
'Just a few PropSTICK Kit bare PCBs left!
Post Edited (Phil Pilgrim (PhiPi)) : 10/24/2008 8:05:09 PM GMT
Paul Baker
http://www.national.com/ds/LM/LM2940.pdf
http://www.national.com/ds/LM/LM2937.pdf
Beau Schwabe
IC Layout Engineer
Post Edited (Mike Green) : 10/24/2008 10:00:45 PM GMT
OBC, sorry I took the thread a little OT there. Don't forget the capacitors that the regulators need to provide a steady output. You mentioned the 7805, I'm sure because they are readily available, as most Radio Shacks carry them. Sounds like the general consensus is to use the right tool for the job. Either a fixed voltage 3.3V model, or a LM317 (which is also carried at most Radio Shacks) with a couple of extra resistors.
Since they've got to get the Propeller from somewhere online anyway.... They ought to just order a good fixed 3.3V regulator at the same time... Just my thoughts
Brian
diode with a suitable current limiting resistor?
blake
"Can't sleep, clown will eat me."
Bart Simpson
Signature space for rent, only $1.
Send cash and signature to CannibalRobotics.
