Error: Could not find packages
Hi. I'm newable to Javelin, and I have 4 weeks left before my project has to be ready for the examination.
I had to create the following folder to remopve this error, but I'm pretty shure that I need some files as well.
c:\programfiler\Parallax inc\Javelin\ Stamp\IDE\Projects/stamp/peripheral/sensor/compass/HM55B/ is empty.
Is there any files that I need to download to get my kompass working propertly? And where do I get theese files?
I need packages for: Int32, Compass HM55B, and receiving Text signals from 5V com-port.(Using GPS EM406a from GlobalSat).
My project is to create a GPS-controlled RC-car with realtime programming. And I need this project to be up and running to get my Bachelor degree.
I will be gratefull for any ideas that helps.
Actually, the path is
c:\program files\parallax inc\javelin stamp ide\lib\stamp\peripheral\sensor\compass\HM55B
regards peter
I belived that theese files was the program to be uploaded to the Javelin controller.
But now I understand how to use them.
Thank you for your quick replay.
http://www.parallax.com/tabid/430/Default.aspx
I do not know about a EM406a gps class.
There is a class for the Parallax GPS module.
Receiving serial signals (TTL=5V) is done by using
the Uart class.
regards peter
Got an compiling error that refered to IntegerMath.
Again, Thanks!
Edit:
It seems to that I need the IntegerMath class as well, But I can only find Int32 while searching for it.
Hopefully this will be the last claas I need for this Compass
but both packages go into folder ...\lib\stamp\math
I attached the IntegerMath class for your convenience.
Most classes can also be found at the JavelinCode yahoogroup:
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/
Just navigate to lib/stamp/math to find all available math packages.
regards peter
Just some bugging left on the compass then. Cp1. would not poll.
otherwise the datapin, clockpin and enablepin will not be
steady.
regards peter
But I still got nothing.
It seems that the >>m_status = CPU.shiftIn(m_DinDout, m_Clk, 4, CPU.POST_CLOCK_MSB );<< always want to end up with the value 0.
This is in the HM55B.java
I added a >>System.out.println(m_status);<< right after the >>m_status = CPU.shiftIn(m_DinDout, m_Clk, 4, CPU.POST_CLOCK_MSB );<<
Post Edited (ThaEagle) : 10/23/2008 6:01:19 PM GMT
http://forums.parallax.com/showthread.php?p=552799
regards peter
http://forums.parallax.com/showthread.php?p=549017
http://forums.parallax.com/showthread.php?p=544194
http://forums.parallax.com/showthread.php?p=674307
regards peter
I'll take a look at the sites.
