Faster Motors for BOE-Bot??? — Parallax Forums
RoboticsProfessorRoboticsProfessor Posts: 54
edited 2008-10-24 00:18 in Robotics
I'm just finishing a line maze bot with BOE-Bot, and I can see it does the maze well.
But in a "fastest time" contest, I'd be in trouble.
Anybody have any experience with faster servos?
Or will I have to replace servos with motors to get more speed?
  • SRLMSRLM Posts: 5,045
    edited 2008-10-21 06:23
    The Parallax servos are .28s for 60 degrees.
    This servo is .15s for the same
    While this servo is .11s. You'd have to modify this one to continuous rotation.
    You could also just get bigger wheels.
  • iDaveiDave Posts: 252
    edited 2008-10-21 06:53
    Thanks for the info SLRM..I've also been looking for a faster servo for my telepresent robot
    "THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
    edited 2008-10-22 02:26
    Or get some of these www.pololu.com/catalog/product/993 as seen here www.pololu.com/catalog/product/975
    - Stephen
    edited 2008-10-22 03:00
    Personally, I'd stick with servos: they are drop in replacements for the same price as the motors (at least the pololu one is). However, at 440 RPM the motor is certainly faster.
    edited 2008-10-22 17:13
    You can speed up your existing servos somewhat by increasing their supply voltage from 6 volts to 7.5. Jumping to 9 volts is pushing it. Make sure your Stamp gets regulated 5 volts.
    Some servos are definitely faster than others, if you want to check specs and swap them out. But I agree with Franklin that replacing servos with gearmotors will give you the widest range of speed & torque. Pololu and Solarbotics both offer a variety of gearboxes (brass and plastic, each available·in multiple gear ratios) and the Pololu·dual motor controller is small, cheap and works well: http://www.pololu.com/catalog/product/411.·You can use up to 9 volt motor supply voltage. The controller adds "set & forget" speed control so you don't have to send a continuous string of pulsouts to keep your motors moving, so you're free to monitor your sensors and react accordingly.
  • gelfling6gelfling6 Posts: 60
    I did a little cross-platform working a few years back, between the VEX robotics system( Pre-IFI, When Radioshack sold BOTH), and the Parallax BOE-BOT. I was surprised, the VEX motor modules ran a little faster rotation, when driving them off the BOE & the Homework boards. The output frequency was (a) a little wider, and (b) offset a few Hz., but virtually identical operation..
    I also ran into a few fairly easily servos at a local RC-Hobby store, which ran a little faster too, but were a bear to modify to constant rotation. (mechanically, easy, but connecting a 5K Trim-POT to the outside, was tough.. too much signal drift.
    they seemed sensitive to RFI.) I bought a pair, with the idea of replacing the stock CR-Servos from Parallax, which were beginning to "Scream" (motor bearings worn. result, massive armature chatter.)..
    Stephen
