New Soldering Station
I just received my new soldering station. It’s a Velleman VTSSC40N. My old soldering iron just wasn’ cutting it. It was only 25 watts and I had messed up the tip long time ago. I plan to use the new station to solder small PCBs and Basic Stamp projects.
So, now with this new station, I’d like to setup it up right (pre-tinning?) and take care of it for the long term. What recommendations do people have for getting started? I am planning on buying a tip cleaner soon, but in the mean time would an old wet sponge be ok? Or should I just wait to get started until I have the tip clearner? To clean up parts before & after soldering, is alcohol or acetone better? Or something else?
And once I start soldering, what temps are recommended? My new soldering station is digital and is suppost to be fairly accurate in temperature.
Thanks in advance,
Randy
Thanks in advance,
Randy
- Stephen
The new soldering station I've got is a 48 Watt station.
The tip cleaner I am getting is this http://apogeekits.com/solder_tip_cleaner.htm
I did get a couple of extra tips in case I totally mess it up while I am learning how to use my new station. Here's the specs on my station;
http://apogeekits.com/soldering_station_digital.htm
Randy
Paul Baker
Post Edited (Paul Baker (Parallax)) : 10/21/2008 6:28:37 PM GMT
