You have 24VAC and you want 5V to run a uc, here is a circuit I designed — Parallax Forums
metron9metron9 Posts: 1,100
edited 2008-10-20 18:58 in General Discussion
Actually it is a circuit that I found to run a indicator LED directly from 110VAC mains. I increased the capacitor size and added a low dropout 5V regulator. What I had was a standard 24VAC transformer from an old furnace that I wanted to use to drive a 220VAC relay with a 24VAC coil.
Originally I blew up a 7805 because the transformer when put through a bridge rectifier actually output about 38 volts. I could not find a regulator that would allow over 38VDC input so I made this. I can get a stiff 22mA at 5VDC using the following circuit. I thought it might be instructive for others needing a bit of low voltage to run a uc when only high voltage AC is available.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
    edited 2008-10-20 04:48
    Take a look at this if you need·a little more in the way of more amps ·I have used in a project and it works very well with a 24 volt tranformer
    You can get a kit with a board and all parts for this regulator at the Nuts and Volts Store online
    I was able to power a Basic Stamp and a 2 line LCD Display with a back light and power a·optic sensor and a Ds1302 time chip ·it was·for a project that·I built
    http://www.national.com/ds/LM/LM2576.pdf
    I hope this helps
    ··Thanks for any·idea.gif·that you may have and all of your time finding them
    Sam
    Post Edited (sam_sam_sam) : 10/20/2008 5:00:51 AM GMT
  • metron9metron9 Posts: 1,100
    edited 2008-10-20 06:10
    I shall file it in my datasheet collection, thanks.
    metron9,
    Just curious... why a full wave bridge rectifier?· A single diode (half-wave rectifier) would provide a more reasonable output voltage closer to 24V and certainly allow more current than 22mA.
    Beau Schwabe
    IC Layout Engineer
