building computer controlled car and need help with some code
Hey everyone again [noparse]:)[/noparse] I have been working with a VB program that communicates with the SX chip through a serial connection and I have run into a stump. I have been able to get the drive motor to go forward and backwards with the arrow keys, but now I am working on the servo to steer it. I am using a digital Futaba servo FP-S148 indirect drive.
The problem I am having is that now that I have added the code to center the servo when no activity is being sent, the drive motor will sometimes continue to move even though I do not have a button pressed. I was thinking about using an interrupt, but I am not sure about the timing on the chip and using the pulsout command.
Here is the code so far :
Thanks for any help in advance!
' Original Author.... Jon Williams, EFX-TEK
ID "srobot"
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX, BOR42
FREQ 4_000_000
' I/O Pins
Drive1 PIN RC.7 OUTPUT
Drive2 PIN RC.6 OUTPUT
Turn PIN RC.5 OUTPUT
RX PIN RA.0 INPUT ' via MAX232
Sout PIN RA.1 OUTPUT
' Constants
IsOn CON 1
IsOff CON 0
Baud CON "N9600"
SYNC CON $80 ' start of packet marker
MTR_X CON $01
MTR_Y CON $00
MTR_Z CON $7F
' Variables
tmpW1 VAR Word
cmd VAR Byte
idx VAR Byte
in VAR Byte (3) ' move per motor
DriveMotor VAR Byte
SteerMotor VAR Byte
ExtraMotor1 VAR Byte
f var Byte
DELAY_MS SUB 1, 2 ' shell for PAUSE
RX_BYTE FUNC 1, 0 ' shell for SERIN
PROGRAM Start
Start:
PLP_A = %0000_0001 ' set pull-ups
PLP_B = %0000_0000
PLP_C = %1111_0000
Main:
for f = 1 to 136
PULSOUT Turn, 150
'DELAY_MS 20
cmd = RX_BYTE
Next
IF cmd <> SYNC THEN Main
Get_Moves:
FOR idx = 0 TO 2
cmd = RX_BYTE
IF cmd = SYNC THEN Get_Moves ' fix busted packet
in(idx) = cmd
NEXT
MoveMotor:
DriveMotor = in(0)
SteerMotor = in(1)
ExtraMotor1 = in(2)
IF DriveMotor = "1" THEN
Drive2 = IsOff
Drive1 = IsOn
ELSEIF DriveMotor = "3" THEN
Drive1 = IsOff
Drive2 = IsOn
ELSE
Drive2 = IsOff
Drive1 = IsOff
ENDIF
'SEROUT Sout, Baud, DriveMotor
GOTO Main
SUB DELAY_MS
IF __PARAMCNT = 1 THEN
tmpW1 = __PARAM1
ELSE
tmpW1 = __WPARAM12
ENDIF
pause tmpW1
ENDSUB
FUNC RX_BYTE
SERIN RX, Baud, __PARAM1
ENDFUNC
Nick
