The beginner's setup for micro controllers, what would you put?
While somethings will vary with the micro controller, what would you put?
Things like common resistor sizes, and their ratings.
Things like good lighting.
Magnifying glass.
Solder iron
Solder
Wire cutter
needle nose pliers
wire for jumpers. I like to use cat5 cable, cut up.
I'm thinking for resistors for 5v micro controller like the basic stamp and the sx
all 1/4 watt.
220 ohm to protect the I/O pin
470 ohm for LEDs
1k ohm for LEDs
4.7k ohm pullup/pulldown
10k ohm pullup/pulldown
Magnifying glass.
Solder iron
Solder
Wire cutter
needle nose pliers
all 1/4 watt.
470 ohm for LEDs
1k ohm for LEDs
http://www.goldfeverprospecting.com/ledloupe.html
I got a couple at American Science and Surplus for about $3 apiece - I imagine you can get various versions from many different places.
Soldering wick and a cheap kitchen sponge (for cleaning the soldering iron's tip) are as important as the iron and solder themselves.
0.1 uf caps are good for decoupling, should be 1 (sometimes more) per IC
How about a good Solderless breadboard with a breadboard mounted regulator board, Circuits don't work right unless they are fed the correct constant voltage. Don't count on a wall wart power supply to provide this, you need a good regulator.
For jumper wires, I prefer these http://forums.parallaxinc.com/www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=126342
they cost more than wires stripped out of cat5 cable, but after using these, I'll never go back.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
A logic probe is nice to have.
I use a small Hemostat constantly; they're similar to tweezers, but their jaws can be locked.
http://www.allelectronics.com/make-a-store/item/HM-2/5-CURVED-TIP-HEMOSTAT/-/1.html
Heat-shrink tubing is hard to live without.
Don't forget to safely ground both you and your workstation to protect against ESD damage.
This post is a work of art. Variations in spelling and grammar are intentional, artistic endeavors that add value to all of mankind.
