what do you guys do with "coasters"?
We all have probably produced a printed circuit board (via homebrew or "professional" methods) that is a failure for some reason. Circuit changes, mistakes in the layout, something screwing up in the board making process, etc... Sparkfun calls these kinds of boards "coasters", implying they are not much more useful than a beverage coaster (https://www.sparkfun.com/commerce/product_info.php?products_id=8477)
But as resourceful people, I'm pretty sure we do more things with it. For me, I use it for solder/drilling practice.
What do you guys do with "coasters"?
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Beau Schwabe
IC Layout Engineer
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
The first picture is of a simple go-no-go gauge for a connector assembly to ensure proper tightening. The second one is simple gauge to verify lead length of leads coming through the bottom of the board where lead length had to be less than 0.063" (IPC standard is 0.098")
~~ dRu ~~
One person uses them as joint bearing surfaces in hand-made teddy bears.
We also make clipboards out of them.
A couple of our staff have made jewelry.
Most of it goes to the local HP recycling plant.
Ken
Parallax posesses power beyond belief.
Believe in it.
I had an sx proto board, tha I blew up the sx. I had 1/8 watt with a bunch of LEDs off an SX. Lets just say after doing RB=255, it wouldn't program anymore. So I dremeled off the prototyping area, so I could keep the SMD. Radio Shack doesn't sell SMD prototyping boards.
