Problem with Float32Full
Hello!
When i run this program:
I get "ACos(0,2)= 1.369439"
But isn't Acos(0,2) = 78.46304097?
What am·I doing wrong?
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ text : "vga_text" Math : "Float32Full" Floatstr : "FloatString" Pub Main Math.start text.start(16) Floatstr.SetPositiveChr(" ") text.str(string("ACos(0,2)= ")) text.str(Floatstr.FloatToString(Math.ACos(0.2)))
use text.str(Floatstr.FloatToString(Math.Degrees(Math.ACos(0.2))))
I didn't check the documentation, it may be Math.FDegrees
John Abshier
There are 2 * pi radians in a circle, the equivalent to 360 degrees.
and 1.3694 * 360 / ( 2 * pi) = 78.46.
I think the library you mention already has funcitons for converting between radians and degrees.
