unable to initialize Keyboard/mouse combo object
I was trying to use your Keyboard/mouse object.It says to:
“Applications should call config.GetPin(DeviceType) to get the pin for the device.”
I tried placing the call like this:
I also tried doing this "config.GetPin(#VGA1) - not succesful
and I did not get any display on the VGA Monitor.(I have the monitor hooked up to "Propeller Proto Board and wired per instructions and it does work when I use the VGA object to display text.
What I am I doing wrong.
Siri
Pub Start | char, mx, my
config.Init(@pininfo,0) 'initialize config setup
config.GetPin(CONFIG#VGA1)
kbm.start(config.GetPin(CONFIG#MOUSE1_DATA),config.GetPin(CONFIG#MOUSE1_CLK), {
} config.GetPin(CONFIG#KEYBOARD1_DATA),config.GetPin(CONFIG#KEYBOARD1_CLK))
config.Init(@pininfo) 'initialize config setup
} config.GetPin(CONFIG#KEYBOARD1_DATA),config.GetPin(CONFIG#KEYBOARD1_CLK)) ,config.GetPin(CONFIG#VGA1)
Siri
some code that calls a "pindefs" file for it's I/O information.
something like this:
propeller.wikispaces.com/PinDefs.spin
If you place the actual number of the connected item does it work?
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
You are wright it is looking for "PinDefs"They are in a another object which this calls.
Here is the initialization part of the KBM driver Test - I was trying out the Test program which was included in the kbm oject found in the OBJECT section.
{{ KBM driver test Tim Moore July 08 }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ '1 Cog here kbm : "kbm" '1 COG for mouse and keyboard uarts : "pcFullDuplexSerial4FC" '1 COG for 4 serial ports config : "config" 'no COG required Pub Start | char, mx, my config.Init(@pininfo,0) 'initialize config setup kbm.start(config.GetPin(CONFIG#MOUSE1_DATA),config.GetPin(CONFIG#MOUSE1_CLK), { } config.GetPin(CONFIG#KEYBOARD1_DATA),config.GetPin(CONFIG#KEYBOARD1_CLK)) config.GetPin(CONFIG#VGA1) waitcnt(clkfreq*3 + cnt) 'delay for debugging uarts.Init uarts.AddPort(0,config.GetPin(CONFIG#DEBUG_RX),config.GetPin(CONFIG#DEBUG_TX),{ } UARTS#PINNOTUSED,UARTS#PINNOTUSED,UARTS#DEFAULTTHRESHOLD, { } UARTS#NOMODE,UARTS#BAUD115200) 'Add debug port uarts.Start 'Start the ports uarts.str(0,string("KBMTest",13))Thanks,
Siri
pd : "PinDefs" ' I/O configuration file text.start(pd#TV_DAC1) snd.start(pd#AUDIO1) fsrw.start(@ioControl) fsrw.mount(pd#FSRW1_DO,pd#FSRW1_Clk,pd#FSRW1_DI,pd#FSRW1_CS)I'm guessing that config.GetPin(CONFIG#VGA1) should be something like start.vga(config#VGA1)
and kbm.start(config#MOUSE1_DATA,config#MOUSE1_CLK)
OBC
Post Edited (Oldbitcollector) : 10/17/2008 8:36:43 PM GMT
I got it working.
Siri
