Sure Electronics 64x32 LED Matrix...
Here is the start of a Propeller driver for the LED matrix from Sure Electronics.
This was a little bit tricky to get working since the data sheet is not the best...
However after reading the thread for the SX48 driver I managed to make sense of the whole thing...
The Matrix have been bit mapped for easy use and the driver runs in a separate cog...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Experience level:
/Bamse
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
However the SX thread suggest that you can get it cheaper from E-bay...
http://forums.parallax.com/forums/default.aspx?f=21&m=282223
My display had one dead Green LED though, if you look closely at the R in GREEN you might be able to spot it...
Experience level:
/Bamse
BTW: Here is the link to the SX48 / 28 versions that·Bamse mentioned: http://forums.parallax.com/showthread.php?p=746212
You can get them on Ebay for about $58 with free shipping: http://cgi.ebay.com/6432-Dot-Matrix-3mm-Bicolor-LED-Info-Board-Demo-Board_W0QQitemZ250305636655QQihZ015QQcategoryZ26206QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or at the Sure Electronics site for $37 + $21 shipping from China. I have ordered many of them and they have great products!
http://www.sureelectronics.net/
Totally $49.70...
I decided not to get the demo board, maybe that saved me on the shipping...
Experience level:
/Bamse
Experience level:
/Bamse
Channel: #propeller
I want to make a PONG game...
I got the MCP3008 hooked up and the Commodore Paddles connected...
However it looks like the pots in the paddles are logarithmic so I need to figure out how to convert it to a linear scale...
I basically need to convert a logarithmic value of 0-1024 to a linear value between 0-1024 using Spin and integer.
But that is something I'll look into tomorrow...
Experience level:
/Bamse
Still just goofing around...
Experience level:
/Bamse
Post Edited (Bamse) : 10/30/2008 3:16:14 PM GMT
By the way, I updated my previous post and added the code...
It was late, sorry I forgot to attach the code...
Experience level:
/Bamse
This looks like an equivalent to the Sure Electronics 6432 obsolete board with some very minor changes.
Tim
http://www.youtube.com/watch?v=T8FWoQeLcO0
