HomeWork Board Current Draw - Wake/Sleep
The manual page 5 says the board draws 10ma awake and 40ua sleep with the LED off.
www.parallax.com/Portals/0/Downloads/docs/prod/boards/HomeWorkBoard-v1.3.pdf
My Homework boards (2 tested) draw 16ma awake and 9ma sleep.
I use a digital bench dc power supply with voltage and current readouts, and run the code listed in the manual.
Why is there a great difference between my readings and Parallax' readings?
Because you have an LED still on?
Because you've got a USB adapter connected? Or the serial port still connected?
BTW, does the on-board LED turn off in sleep mode?
The LM2940 voltage regulator has a rather high quiescent current, up to 10 milliamps even at zero load, and maybe that accounts for the excess 9 miilliamps. It is a low dropout regulator, but certainly not micropower. The discussion of the battery life it kind of off target, if it does not include the regulator in the calculations.
Tracy Allen
www.emesystems.com
The homework board LED is connected to the 24LC16 clock line, so that when the clock is high or when the Stamp is sleeping, the LED is off. The LED flashes very rapidly when the clock is active, that is, any time the Stamp is executing code. A clever scheme.
I notice that earler versions of the homework board (A &
Tracy Allen
www.emesystems.com
