Needed: wisdom concerning the use of DIP chip sockets with the Propeller
Hi all,
I've decided to graduate my Propeller project to a soldered version, so I was wondering if anyone had any comments or suggestions about using a DIP chip socket for the DIP version of the Propeller. I intend on counting pulses at a rate of up to about 1 Mega Hz, so I'm concerned that a DIP socket might have some frequency issues.
thanks,
Mark
thanks,
Mark
Generally speaking, if connections are short compared to the wavelength of the signal, you don't have to bother about them.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 10/13/2008 3:00:31 PM GMT
What I'm trying to say is: Pay attention to the physical reality of what you have and what you're proposing and don't get caught up in appearances (and the names of things). You're already using a socket of some sort (a breadboard). Is what you're proposing that much different?
And to Mike:
Yes, that makes a lot of sense. I never thought about it that way before!
Thanks to you, too!
Mark
--Micah
Leon
And to Cluso99,
What would you say constitutes a "decent socket" - Do I need to use gold contacts or something? My purposes are purely research at this stage, so if my circuit lasts 15-20 months without getting fried, I'll be dancing on air.
thanks,
Mark
If you are only making a few then just go ahead and use the machine pin sockets. On the other hand if you are making a large batch and cost is a sensitive issue there is nothing wrong with using a standard dual-leaf 40-pin DIP socket. They work just fine for most cases. I've used both styles and don't have any issues with regular sockets.
Think about it. Most early systems had CPU's that were 40-pin DIP chips. Almost all of those just used the plain dual leaf sockets. How many TRS-80's, Apple II's, and IBM PC/XT clones are out there that still work fine today? Quite a few. All of them used the regular sockets. A lot of the PC/XT clones ran their 8088 at 10Mhz with the chip in that sockets. When you look at it from that perspective using one for a Propeller and counting pulses at 1Mhz isn't any stretch at all....
Robert
