Thanks for the reference to Wikipedia...I had forgotten that its almost the universal reference guide now. There appear to be some good links on adaptable implementations if I can't find a Prop one aleady done.
From working with modbus at Square D/Modicon many years ago, I remember that it is not a straight forward async protocol, but has some critical inter-byte timing issues to keep the data flowing, although a lot of the implementations try to ignore them, creating non-standard "standard" implementations.
This project is a video display panel for a battery monitoring system, for which the Prop seems to be a good fit.
I'm tooling with a hybrid serial/parallel protocol right now. more of a rough draft... Semi synchronous, scalable 4/8/12/16 bit wide + Strobe. Commands are bidirectional (send/receive), traditional control bus for parallel interface is integrated on databus, CRC checksum disable feature, Auto baud rate feature. Ping/pong timing for sync (no standard timing). It's designed as a high speed bidirectional interface between two or more props.
Post Edited By Moderator (Chris Savage (Parallax)) : 10/14/2008 3:55:44 PM GMT
From a glance at wikipedia about the topic it doesn't look too hard to do:· http://en.wikipedia.org/wiki/Modbus
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
-Joe
www.tdswieter.com
