Wait tick - Need help
I have the code for getting the prop to wait a second but is there a way to get it to wait a tick.
A tick is a 10, 000 of a millisecond.
The code for getting it to wait a millisecond is:
I thought:
would work but it waits for more like 10 seconds.
Can the prop handle waiting for such small amounts of time?
Thank you
Building Blocks To The Propeller Chip A web site designed to help people who are new to the propeller chip.
Guitar Hero controller using the prop (WIP) --> HERE
Post Edited (computer guy) : 10/13/2008 8:04:21 AM GMT
waitcnt(((clkfreq / 1_000 * Duration - 3932)) + cnt)
I thought:
waitcnt((((clkfreq / 1_000 * Duration - 3932)) + cnt) / 10_000)
Thank you
is adding the 3932 ( which I'm assuming you're using as an offset that spin takes between getting the cnt value for the calculation ) and the current cnt value, before / 10_000 try doing / 10_000 first
However it still takes 10 seconds if not longer.
nop··· ' takes 4 clocks
nop··· ' takes 4 more
There's no way you'll get SPIN (interpreted) code to wait for such a short time, as there's a·significant overhead for the waitcnt SPIN instruction.· PASM runs ~50x faster than SPIN.
Note that this is ONLY if you want to wait for ONE tick, or very few.· If you want to wait for a few hundred ticks, you're getting within the realm of possibility.· It won't be cycle accurate like PASM, but it might be good enough - the overhead is more or less fixed, so waiting for (overhead + 10) is possible, but (overhead - 10) isn't.
In the example you've given, if 'Duration' isn't a constant, the code has to do an integer multiply of (1_000·*·Duration), then divide clkfrq by the result, both of which take some time.· The -3932 is probably compensating for the time passing while the calcs are done.· If Duration IS a constant, then the compiler could do all the math (except +cnt) at compile time, and that -3932 would probably cut down to -350 or so.
I hope that all makes sense.· [noparse]:)[/noparse]
Jason
Post Edited (JasonDorie) : 10/13/2008 8:32:02 AM GMT
Thank you
Jason
Someone please correct me if I'm way off there.
If this is what you're trying to do, it's probably in your best interests to learn PASM.
Jason
I have a variable "output_time". This has a value like 59334592.
I need to increment a variable "temp" by 1 and then compare it to output_time.
If they match then continue else keep incrementing and compare.
waitcnt( cnt + output_time )
...it'll take the current cycle count, add your 'output_time' value, and then wait until the cycle count reaches that new number. Assuming that your 'output_time' value is in clock ticks that'll work just fine. If you're running at 10MHz, that would be exactly right as 1 tick would equal 1 clock. At 80MHz, 1 tick = 8 clocks, so you'd need to use:
waitcnt( cnt + output_time*8 )
...and since *8 is just a shift left by 3, the compiler should optimize it for you and it will take very little time.
Does that help?
Jason
Post Edited (JasonDorie) : 10/13/2008 8:50:48 AM GMT
I will see how I go with the information you have provided.
Its not doing anything.
I have that code within another repeat statement.
If I change the code to
It works fine.
Is there some rule about having a repeat statement within another?
Thank you
Post Edited (computer guy) : 10/13/2008 9:55:35 AM GMT
if they're both 0 ( uninitialised )·it won't do anything as 0 (temp) is not < 0 (new_time)
or if·temp·is greater than or equal to·new_time
It doesn't work.
Thank you
can you post more of the code?
I managed to get it working after setting the 2 variables properly.
Thank you
