hippy, could you assist with this?
hippy,
would you mind helping adjust this code to properly support 22x13 character size allowing
Aigeneric access to larger custom fonts on screen. It's based on your AiChip video driver
from a while back.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
from a while back.
OBC
will see the obvious that I'm missing. Thanks for all you do here.
OBC
what is it exactly your after? and would it be set to that size or would you want it to be changeable on the fly?
if the font is twice as large. The exact size really isn't a big deal.
The size I specified was a combination I found by playing with the row/cols settings.
OBC
but surely that would eat memory more than 8x8 tiles with 2x2 or 4x4 bigtiles, then the MAP so to speak?
OBC
Are you planning on using the font characters for 'tiles' in the game? If so, you could accomplish the same thing by putting 4 8x8 characters together to make one 16x16 'block' on the screen (a lot of tile engines do that). You could even make 'larger' letters the same way without affecting the code. It would save from adding complexity into AIGeneric.
I would think that if you were truly wanting a 22x13 font you would have to use a method similar to Graphics.spin instead of what is in AIGeneric. That way you could scale/rotate/etc. on the text.
[noparse][[/noparse]Edit:] If you are going after a 'larger' display have you thought about just reducing the resolution (maybe 192X160 like the Hydra HEL engine)?· That would give you 'bigger' 8x8 characters, and it would be fairly fast to implement.· In 8x8 characters/tiles that would give you a 24 x 20 area to work with.·
Post Edited (trodoss) : 10/13/2008 2:00:13 PM GMT
correct adjustments to make it work correctly.
Using redefine in AiGeneric, this text driver becomes a nearly perfect platform
for an easy game design.
I'm thinking that something simple like this might promote a little more game
creation around here. [noparse]:)[/noparse]
OBC
I don't know if you will find it useful or not, but I put together a 'quick and dirty' program that can generate AIGeneric fonts from a bitmap.· I have been using it in a little game project I have been working on myself.· [noparse][[/noparse]Edit:] It might help someone if they wanted to define the tiles upfront (as an alternative to using 'redefine' in code).
Usage:
FontMaker.exe [noparse][[/noparse]input_bitmap_filename] [noparse][[/noparse]output_filename]
NICE! I will try this later today. [noparse]:)[/noparse]
OBC
As far as adjusting the resolution, I might expirament with AiGeneric_Driver_TV to see what can be done by adjusting the timing, etc. I am sure someone more familiar with the code could accomplish it much faster/better, but it might be a good excuse for me to get my 'feet wet' and/or do some research in the Hydra book.
Also, I highly agree that AIGeneric would be a great platform for learning about game programming.· Working with·the Prop·brings back fond memories of the TI-994A, and pouring over books like David Ahl's "BASIC Computer Games" (the "Creative Computing" magazine book).·[noparse][[/noparse]Edit:]·http://www.moorecad.com/classicbasic/index.html· <sigh!> Yep, I am officially "old" [noparse];)[/noparse]
--Tro
Post Edited (trodoss) : 10/13/2008 2:56:32 PM GMT
then people could redo C64 style games [noparse]:)[/noparse]
I forgot to mention in my posting of the code that I was working with a 96 character font, instead of 128.· If you were going to 'test' it you would have to use all caps for the characters.· In order to do the full 128 just increase the size of the bitmap by 8 pixels, and add in the lower case letters.
Just in case I sound like I am speaking jibberish, here is an edited .bmp that would work with both capital/lower case letters.
It sounds like you are creating similar (or an improvement on) the "DK" engine, used in Dodgy Kong, only with a lower resolution(?) and higher performance. Sounds like a great enginge though.· I was always a big fan of C64·games.··The GFX Lite·looks like it will come with a·wealth of code to show off what it can do. So would US buyers be able to order these in November?
As far as sprites/collision detection/etc., those are great, but not always absolutely necessary (especially in 'simple' tile-based games). I would think a 'double buffered' display or page-swapping (to avoid 'flickering') would be about the extent that would be needed, but a sprite engine is certianly a "nice to have" when the user understands the concepts of sprites, collision detection, etc.· [noparse][[/noparse]Edit:] I will certianly be the first to admit my own ignorance of game programming.· I write the 'necessary evil' (business apps) for a living
Post Edited (trodoss) : 10/13/2008 4:28:56 PM GMT
and incorporate them easily into Propeller games.
OBC
You could probably use some of the other tools that came with the Hydra book/CD and convert those to 'usable' sprites for a game, depending on what engine you use and tile size. Re: NES sprites - I think the NES pattern table was a series of 4-color 8x8 tiles that were 'constructed' in the games into 16x16, 16x32, etc. More 'space concious' than easy to work with. Wth the right coding both in spin/asm and PC-based (either with an existing NES tool like YY-Chr, or one you/someone creates for editing the pattern table(s)) you could probably take the existing Dodgy Kong engine and make a generic NES engine.· [noparse][[/noparse]Edit:] Or, as Baggers said, maybe wait for his C64 engine.· Sprites, scrolling, etc. are all possible if you can·execute 3D rendering [noparse];)[/noparse]
Post Edited (trodoss) : 10/13/2008 9:32:02 PM GMT
Attached is a version (AIGENERICcf) which is adjusted to 24x22. It is reasonably close for the purpose
I have in mind. I figure someone might find it useful as well.
OBC
Very cool.· I would be one·such monkey who would find it useful [noparse];)[/noparse]
