TV Graphical display - help needed
Hi everyone,
I need help writing some code that can use the graphics driver to display 5 squares on a tv.
The squares will be in a horizontal line and be:
Green Red Yellow Blue Orange.
They will need to be able to be hidden.
Something like that.
I have never done graphics programming on the prop or any device for that matter.
Any help would be greatly appreciated.
Thank you
Building Blocks To The Propeller Chip A web site designed to help people who are new to the propeller chip.
Guitar Hero controller using the prop (WIP) --> HERE
If green == true showgreen else hidegreen
Thank you
Other than that just grab the graphics demo and start playing with it. Its fairly easy to use.
The squares will just appear or disappear.
I have tried playing with the graphics demo in this thread.
http://forums.parallax.com/showthread.php?p=752119
However have gotten no where.
Thank you Steven
After clearing the screen, all screen tiles is the tile array are the space tile with some color, usually black. So, just make new solid colors in the color table.
Then, either replace tiles in the tile array with space tiles with the appropriate color, or just change the bits in the tile array that correspond to color (I think th elower 6 bits in each word).
Each tile is represented by a word in the tile array.
I understand that I need to set the tiles colors in the tile array but have no idea how.
Thank you Rayman
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ text : "tv_text" PUB start | i text.start(12) text.setcolors(@myPalette) repeat text.out(0) repeat i from 1 to 5 text.out(12) 'set color for block text.out(i) text.str(string(" ")) 'draw block (6 spaces) waitcnt(clkfreq>>2+cnt) waitcnt(clkfreq+cnt) text.out(1) repeat i from 1 to 5 text.out(12) 'clear color for block text.out(0) text.str(string(" ")) 'draw block waitcnt(clkfreq>>2+cnt) waitcnt(clkfreq+cnt) DAT myPalette byte $02,$02 'black/black byte $02,$D8 'green/black byte $02,$38 'red/black byte $02,$9E 'yellow/black byte $02,$88 'blue/black byte $02,$18 'brown/blackAndy
Just a quick question, where can I find the color codes?
Andy, your example is exactly what I need.
Thank you
http://www.rayslogic.com/propeller/Programming/TV_Colors.htm
