Is a current sink the opposite of a current source?
Is a current sink the opposite of a current source?· In other words, a 25ma sink will draw 25ma no matter what the voltage applied?· As opposed to·a 25ma current source which provides 25ma to a circuit.
The amount of current depends on what's available. A 25mA sink will draw 25mA if that's available. If the source can only supply 15mA, that's what will flow. For that matter, if the source can supply more than 25mA, the Stamp or Propeller I/O pin will draw as much as is available until it burns out.
In mesh analysis, could a current sink be shown as one of the internal currents? (small letter i's). For instance, a current source in parallel with two resistors, with a voltage applied across all three. In this case you would have three loop currents, could one of them be considered the current sink?
po2l
How does one calculate the output impedence of a previous ckt. in order to match the pin input ?
Maybe I'm making this way to complicated.
po2l
po2l (Patrick)
