pololu motor controller
Hello
Does any one out there own a Plolou Dual Serial Motor Controller ... if so i have a noobie question. On page 3 it talks about hooking up the reset pin on the motor controller to the microcontroller. It says you should use a pull-down resistor on the reset line so that if our main controller gets reset the motors do not keep running.
what is a pull-down resistor (definition or what ever) what is a good size and why would it be needed. I know i could google this but tonight i am laid up pretty good and very medicated so please some help would appreciated
Badger the High
Badger the High
To be safe if you pull the reset low with a resistor, the motor controller is held in reset until your microcontroller takes control of the motor controller pins so making sure the motor controller doesn't do something you dont want.
thank you now i understand.. sorry for not looking that up but as i said i am laid up tonight i slipped and almost fell tonight at school and with my arthritis problem it hurt pretty so i am home and laying down and drugged lol
thanks again
Badger
Also if you are running more than 1 controller on the same serial port you will probably see problems of controllers resetting their motor address if you shutdown while commands are being sent to the controller. It took me a while to track down this "feature"
do you know if i can run the power to the motors from the boe.. or did no no understand. remember there are 2 motors and only one controller. the controller has it own power source connections but just wondering if i just hook it to the power connections to the boe
Badger
