Thermisistor
So I am looking at using a thermisistor to monitor a wire's temperature that is submerged in either oil or antifreeze. I am wondering if I insulate the leads up to the sensor would that protect it from a short circuit and any voltage noise going through the wire in the heat sink fluid? If these are problems how would be the best way to sense the wire's temperature? Thank you-Waldo
One of those above might do for you.
-Parsko
