Continuous Rotation Servo's
Hello all, I have a few questions regarding the continuous rotation servo's that parallax sells. First off I am using them in a robotics application, and it seems that I cant find all the information I want from the spec sheet provided. I was wondering what the max load/suggested voltage on the I/O wire would be. The servo's Vdd itself would be 6V, but I wasn't sure about the I/o (white wire labeled on the specs) since it is connected via 5V signal from the micro controller.
I'm also a little curious about the servo's feedback. I am planning on using an opto-isolator so nothing can damage my micro controller, but I was just wondering if anyone else had some problems with this, or if i don't even have to worry about it. I'll probably use it anyway even if i don't have anything to worry about, better safe than sorry. (And frankly its a cool part
A link to the servo spec's can be found here -->here.
Post Edited (Scop) : 10/7/2008 3:20:53 PM GMT
)A link to the servo spec's can be found here -->here.
Now, the signal line is used to control a MUCH larger voltage and current flow from Vdd to Vss. The Vsupply on a Servo can be 5 to 7.5 volts.
Post Edited (Scop) : 10/11/2008 5:13:06 PM GMT
