DC/DC regulator
Timothy D. Swieter
I swear I asked this question in this thread before, but my searches on search.parallax.com are not returning what I am looking for, so here goes again.
I am looking for advice on DC/DC regulators.· Input to the regulator circuit would be 12 to 24V DC.· Output would be 5V or maybe 3.3V too.· One IC I found is this:· http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1042,P36533.
As I said it seems like I ask this before and someone volunteered an easier IC.· I wanted to say it was from National or TI but I am not having any luck finding the reference.
Thank you.
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
Post Edited (Timothy D. Swieter) : 10/8/2008 11:51:32 AM GMT
Thank you.
www.tdswieter.com
What would be the maximum amount of current do you expect your circuit to use? For most power supply applications any of the 78XX and/or 79XX series voltage regulators are hard to beat. They're very simple to use, cheap, readily available and there are many thousands of different circuits on the web.
The regulator in your link is for switching power supplies, which are more efficient than the 78/79XX series regulators, but the 78/79s are much simpler.
Here's a link that shows a basic power supply using the 78XX series regulator.
http://www.aaroncake.net/circuits/supply6.asp
This post is a work of art. Variations in spelling and grammar are intentional, artistic endeavors that add value to all of mankind.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I also corrected by first post because I meant 12 to 24V DC as an input.
There are a couple applications in mind, but nothing solid to calculate numbers on just yet. One app is a small Propeller project with power needed mainly for ICs/display. I wanted to avoid linear regulators and look at DC/DC switching regulators for effeciency as well as to learn more about them. Another application deals with a product design, but those concepts aren't exactly ready to decide on linear vs switching. I just want to be more educated to make the right decision.
If anyone has any other products to look at, let me know.
www.tdswieter.com
Look at this post
http://forums.parallax.com/showthread.php?p=730768
Elapsed Timer For Testing Running Time on A/C Units or other Equipment
Switching Regulating Board Made by Nuts and Volts was a kit·set @ 6.5 volts
http://forums.parallax.com/showthread.php?p=737892
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 10/11/2008 3:08:45 AM GMT
http://www.dimensionengineering.com/DE-SW033.htm
http://www.dimensionengineering.com/DE-SW050.htm
www.tdswieter.com
http://www.recom-international.com/
regards peter
