spin help: wait for pins to be stable
Hi,
I want a process to wait until 2 pins are stable at high and then 5 seconds more.
Any dip on any of the pins during this time should start a new 5 second period wait.
In other words, I want a wait until 5 seconds after the last dip.
Can anyone help me with some codelines for this, please!
Nick
Nick
The only issue there is short period lows on the pin. If they are of shorter duration than you are sampling the pin at you will miss them.
If you need to handle short period pulses you will need a slightly more complicated approach, using an additional cog.
Thanks !
/Nick
I enjouyed writing some democode for this
see attached files
best regards
Stefan
If you can spare an extra pin the code is simple....
1) Read the input pin
2) Make the output pin equal to what was read in #1
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 10/3/2008 4:58:49 AM GMT
When using waitcnt, the systemcounter rollover isn't any problem but doing other thing meanwhile, like checking if the pin has changed, makes it a problem. THANKS A LOT for your democode !
Beau: The idea with schmitt trigger using an extra pin is good, I'll add it to my notes, but doesn't solve the problem in this case.
Maybe I should have told the whole story directly: I'm building a speedometer for my model railway. The input pins are connected to two IR-detectors sensing a model train passing. The detectors are mounted between the ties together with two IR-diodes mounted upwards, so the IR-beams are reflected by the bottom of the loco or waggons. The reflection isn't constant so the pin will vary high-low as long as the train passes (eg. due to gaps between waggons)
What I want to achive is waiting for tho whole train to pass and then 5s extra.
Flow:
Idle state: waiting for first trig of one of the detectors
First trig: store counter, wait for the other detector to trig
Other counter triggered: calculate time and speed, show on display, wait until whole train passed both detectors plus 5 s
Reset display, back to idle state
Nick
[noparse][[/noparse]code]
PUB elapsed_time_msec(p_TimeVar)
'can measure up to approximately 53 seconds at 80MHz
· result := ((cnt >> 1) - (p_TimeVar >> 1))&$7FFFFFFF/(clkfreq/500)
[noparse][[/noparse]/code]
Essentially what we're doing here is forcing the propeller to do·31-bit unsigned·arithmetic instead of 32-bit signed arithmetic.·
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
Post Edited (Ken Peterson) : 10/3/2008 1:31:58 PM GMT
- Bjarne Stroustrup
good ! very short coding
but there was a little bug in it
the new divider for ClkFreq is 2000
as it is the divider of a divider its not the half but the double of the divider before
best regards
Stefan
Post Edited (StefanL38) : 10/3/2008 1:57:24 PM GMT
Still up for a hardware solution?
"...The detectors are mounted between the ties together with two IR-diodes mounted upwards, so the IR-beams are reflected by the bottom of the loco or waggons. The reflection isn't constant so the pin will vary high-low as long as the train passes (eg. due to gaps between waggons)
What I want to achive is waiting for tho whole train to pass and then 5s extra..."
Seems like you need something like a "missing pulse detector".· The circuit below will output a HIGH when there is nothing blocking the sensor, and output a LOW when there is something blocking the sensor.· During brief interruptions where the sensor is not blocked, the output will·still remain LOW.
Assuming a 1.4V threshold, an R value of 330k and a C value of 10uF provides about a 1 second delay.· Increasing the C value to 47uF provides about a 5 second delay.
Since the threshold of 1.4V could vary from Prop to Prop , or another processor such as a BS1, BS2, or SX, it might be good to use a 1Meg pot in place of the 330k resistor so that you can fine tune the timing yourself.· Once you settle on a value that works, you can substitute a fixed value resistor in its place.
Edit:
If the supply is 3.3V rather than 5V, then an R value of 180k·instead of 330k will give comparable results ... still assuming that the threshold is about 1.4V
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 10/3/2008 3:19:03 PM GMT
- Bjarne Stroustrup
@Ken: I would have done the same mistake without testing the code
@Nick: This is a very good example how different solutions can be found if a project is described in DETAIL.
first of all: I'm developing software now for 25 years. The last 5 years especially for
controlling machines. The code below is a result of this experience. So please don't feel
bad if your code is more complicated or less elegant
I guess your code is easier to understand.
Here is a codeversion which I think does what it should to your speedmeasurement.
I think in a quite short way taking care of the train coming from both directions
(it doesn't matter if sensor1 or sensor2 is triggered first)
and takes care of the sensor switching on/off as many times as he likes
and still measure correct.
I added methods that give the absolut time since last rollover to zero of the systemcounter
This code uses the very short and therefore elegant calculating of elapsed_time_msec from Ken
copy &paste this code to the Propeller-IDE to have the comfort of different colors
for comments and PUBs etc.
best regards
Stefan
