PING sensor to measure altitude?
Say I had a flying RC vehicle, such as a Plane or Helicopter. Could a Ping sensor be mounted to the bottom, pointed straight downward, be used to measure the altitude? (up to the distance limit of the PING Sensor)
My thoughts are, that as the ultrasonic burst is transmitted, the vehicle has moved forward by time the reflection returns to the sensor. Or is there an better sensor to use in this type of application?
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Brian
Practically, you need to consider how uniform and "hard" the surface is to the sound waves. You want a good, solid reflection from only one surface to get quality distance measurements and, unless you're flying a helicopter or really small and slow plane in, say, a gymnasium with a hard wooden floor, you'll get sloppy distance measurements.
My only recommendation would be to try it and see if it works. You may have to take more than one reading and use the best two out of three, for example, to filter out the noise. Be sure to report back, so others can benefit from your experience.
