Achievable absolute precision of A/D conversion using the Delta/Sigma principle
godzich
Hi,
This one would be quite hard to test and breadboard myself, so I think I'd better ask. Someone has probably tackled this question before:
What is the achievable DC-precision in an A/D conversion built around one COG running the appropriate DeltaSigma code, and using the schematic below (please copy-paste it into the propeller tool editor to see it clearly):
··························· +3.3V········· │·······
16..24mA··················· │····· ┌─────────┤port in
──────────┐·············· 1nF· │········ │·······
·········· │········ 100kΩ· │····· │· 100kΩ· │·······
·········· ┣──────┳───────┻─┳────┻───────┤Port out
······ 82Ω ·· Cf1µF····· 1nF········· │·······
The conversion speed can be fairly slow,·50..200 samples a second would do. Assuming that the resistors have 0% tolerance (ok, lets be fair and say they are 0.1%) - what is the best UNCALIBRATED DC-precision that can be achieved? Also assuming that the VCC is really 3.300V (precise to the millivolt).
Or is it so that this type of converision is not usable for high precision (>10 bit) DC-signals?
In my case there is a current flowing into the shunt resistor (16..24mA) that I need to convert with the highest precision to a digital value. How high precision can be achieved using this circuitry and just the propeller hardware? Are my component values optimal for this kind of application? Or should I just forget this and get a real14-bit A/D converter for the task?
Where do I find info about the temperature stability for this type of A/D conversion? ·Isn't this conversion depending of the digital input's complementary CMOS transistors gate tresholds (that vary with temperature, and doesn't track very well)? How much better would the performance be if I used a REAL precision comparator with a reference of VCC/2, so that the input pin sees a real logic levels?
Thanks in advance for any comments or feedback on this! Somehow it wouldbe nice to have a complete application note about this subject with all things related to AD-conversion gathered in one place... [noparse];)[/noparse]
Christian
PS: Wouldn't it be nice if we could use the Propeller font in this Parallax forum...?
The future does not exist - we must invent it!
Christian
An easy way around this is to draw up the schematic in PropTool and then post a snipped screenshot of it.
Pull my finger!
It's b0rked though with bitmaps that are grunge under anything but windows.
Grab this one http://forums.parallax.com/forums/attach.aspx?a=22474
From this thread http://forums.parallax.com/forums/default.aspx?f=25&m=225653&p=1
On Ubuntu 8.04 I just popped it in ~/.fonts and next time I logged in it was golden.
Pull my finger!
Sorry, it might be my fault, but aren't we a little of topic here ***grin***
Anyone that has anything on the A2D conversion precision ???
I've learnt a little bit about Unicode too I think. It would seem it is very flexible as to which font is used when displaying oddball character like these.
Cheers,
Evan
I'd be in for some of those answers also. What I have noticed is there is a lot of people posting about using serially driven A/D ICs instead of the Sigma-Delta method. I'm not sure if there is just a lack of info or there has been tests to show it's not performing well. It must be okay though, otherwise Beau wouldn't be planning on embedding the hardware for it in the PropII, - More Prop II info
There have been no publicly shared tests on the performance of the Prop I Sigma-Delta ADC other than the contents of the AN001 archive and some comments on using non-adjacent I/O pins to reduce noise coupling from adjacent I/O pins if you want to squeeze out the best possible performance.
People use external ADCs because they have better performance than using internal Sigma-Delta ADC on the Prop I. These are special purpose chips, optimized for the ADC function. Good ones are not cheap either.
Post Edited (Mike Green) : 10/1/2008 10:50:28 PM GMT
As Mike says, "The I/O pin circuitry is being "tuned up" for Sigma-Delta ADC use"... While the Propeller I is fully capable of performing Sigma-Delta ADC operations, the Propeller II will have a Sigma-Delta ADC that will be better optimized.
As a side note: If you look at the data sheet for several of the ADC's out there many will use a sigma-delta or successive approximation technique not unlike what will be implemented in the Propeller II.
Beau Schwabe
IC Layout Engineer
There are also issues with the Prop's input buffer as it is a fairly normal logic input which is not designed to operate with the input voltage sitting right in the middle of the noise margin. Normally the maximum logic low would be around 0.8V and the minimum logic high around 2V so that 1.6V is sitting in no-mans land. Noise margin means just that, there are really no manufacturer guarantees as to which way it will go, it could even oscillate and almost certainly causes more current to flow through the partially conducting CMOS structures forcing them out of their digital mode (I'd hardly call it linear).
I doubt that the Propeller's structure would be much different. As Mike mentioned the Prop II is taking into account this unforeseen use
One of the advantages of external ADCs is that they allow for reference voltages, separate analog and digital supplies and grounds etc. Plus they are much faster with at 12-bits at 100ksps being fairly easily achieved.
But go ahead and try the comparator approach if you can as I feel it will work for you in this application (or just spend a couple of dollars on a serial ADC).
*Peter*
I'm more tempted to be content with the Prop's input threshold, as-is, and just calibrate the delta-sigma on known voltages at various temps. The input and feedback resistors will make their own contributions to any error, so calibration is necessary anyway.
'Still some PropSTICK Kit bare PCBs left!
Post Edited (Phil Pilgrim (PhiPi)) : 10/2/2008 8:05:41 AM GMT
Paul Baker
THX for all the good and professional comments. I have to admit that I had little too high expectations, before I had a detailed look how this AD conversion is done. Using a digital input in this very "un-orthodox" fashion (without ANY special circuitry) can never be a good performer. Still I'm a little disappointed, since I thought at at least 8 bits precision would have been the minimum achievable. The D/A conversion can produce quite remarkable signal quality, but the AD is just more like a very poor-mans 5 bit AD. I got the wrong impression reading just the data sheet that mentions AD and DA conversion using SigmaDelta techniques. Normally they perform very well and give you many stable bits...
I understand that noise from both adjacent pins and the supply voltage will have a big influence. As well as temperature dependence of the input gate.
I read somewhere that someone had added a third resistor to the AD conversion circuitry, adding a small hysteresis to the input pin. Are there ary studies (theoretical or practical) how this improves the AD conversion precision - or usable bits? Someone's been tackling this thing before...
I have once used a simple schimtt input inverter (HC14) as an pwm-modulated oscillator (two resistors, one cap), and integrated the high/low periods in an FPGA. I achieved more than·9 useful (noiseless) bits, but the linearity was poor. However, in my application I'm not worried about linearity, just repeatibility and resolution...
It would be so NEAT to just use two resistors and capacitors.. [noparse]:)[/noparse] I will continue experimenting and will post my results later...
Christian
You could use the D/A method back into a common LM393 comparator and employ some software to perform successive approximation, that will certainly give you at least 8 bits of usable resolution. A simple voltage divider off VDD can set a reference voltage for the comparator.
*Peter*
That's a bit of a stab at a possible solution to increasing the bit depth. Don't quote me on it.
Also noise increases in direct proportion to input impedance; the higher the impedance, the higher the noise.
Dennis B. Page, Page Radio Company
I probably will lower the impendance a bit...
Most noise to this AD is induced via the VSS 3.3V supply, internally within the Propeller chip. The input treshold varies proportionally with the supply voltage, being roughly half of the supply voltage. This is the reason why there are TWO filter capacitors on the input, to equally divide any high frequency noise on the supply line, and keep the pin centered. Removing either capacitor ruins the AD conversion SNR ratio...
If there is externally induced noise with a known fundamental frequency (as the mains) - then averaging at a multiple of this frequency would help. But for broadband noise, only a heavy averaging filter (in software) will help. In my first application I'm actually adding 8 consecutive samples, virtually adding three bits of resolution, or if keeping the bits the same, improving the SNR by a factor of almost 3.
Sadly· I have not had time to put this togheter to test it, but hope to do so soon. Still it would be nice to hear what kind of performance other people have been avle to squeeze from this archaic but beautiful way of converting signals into the dircrete domain...
Christian
I usually end up using an external ADC in my projects, for various reasons as mentioned earlier in this thread.
Tracy Allen
www.emesystems.com
I've been using an external micro for ADC but had been thinking about trying sigma-delta ... if it's such low resolution with all the complexity in getting it better then it doesn't really seem worth the effort to me.
I don't know exactly what I was expecting but given that ADC chips also use sigma-delta I was expecting more than that, probably also 8-bit minimum.
Any estimates on what sort of base-line resolution the Prop II will have for a typical unrefined sigma-delta ?
Paul Baker
Post Edited (Paul Baker (Parallax)) : 10/4/2008 6:35:24 PM GMT
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
Post Edited (RinksCustoms) : 10/5/2008 2:57:06 AM GMT
