SMT soldering
So I was looking for a IC that met the needs of one of my projects and found it and was able to get samples. The only problem is that I didn't take note of the packaging until the samples came and then checked online only to find out that the package type I received is the only one it's offered in. Now the problem comes into play, I've never soldered any SMT parts but some of the ones I have lying around look like they'd be easy to do. This chip on the other hand gives me a headache when I try to look at the pins. The chip packaging is a thin QFN and it's only 16 pins. I was wondering if it's possible (with a miracle maybe?) to solder that by hand or should I just keep looking to see if I can find a chip that does the same thing but in a more "hobbyist-friendly" package?
Edit: More specifically the package size is 5mmx5mmx0.8mm (I think the .8mm is the pin spacing?)
Post Edited (Phil Pilgrim (PhiPi)) : 10/2/2008 12:00:28 AM GMT
Post Edited (Phil Pilgrim (PhiPi)) : 10/2/2008 12:09:00 AM GMT
I've been having a related headache. Kind of an odd story... I dropped out of electronics work 20 years ago, now picking it back up. The entire SMT stuff, and non-lead solders, are of course, new to me - and making me cRaZy!
After having looked through the confusing types of irons, tips, preheaters, etc. I'm left feeling like a soldering idiot - and I used to do NASA-spec level work ... aaarrrggg!
***Figuring that this is related to Agent Cobalt's original post: What tip / iron should I get? ***
(I'll try a keyword search here too - can't imagine this hasn't been asked before!)
thanks,
Howard in Florida
Buzz Whirr Click Repeat
Post Edited (CounterRotatingProps) : 10/2/2008 12:52:04 AM GMT
I think magnification is a real issue for... one of the guys uses a stereo microscope, which makes perfect sense... using a microscope naturally steadies your hands.
You can get them for as little as $80 on EBAY http://cgi.ebay.com/FIELD-NATURE-20-50x-STEREO-BINOCULAR-BATTERY-MICROSCOPE_W0QQitemZ110295177135QQcmdZViewItem?hash=item110295177135&_trkparms=39:1|66:2|65:15|240:1318&_trksid=p3286.c0.m14
Then you need an adjustable chair, with arm supports and a small table on wheels that fits between your feet... or a good chiropractor... your choice[noparse]:)[/noparse]
What I'm pushing for is an "easy bake" solution... from partsman73...I met him at the PROPEXPO. He is a great guy, always looking for new product ideas and with a little prodding from the rest of us, I think he might offer a starter kit, with the various extras that you need to get started.
Rich
I use a Weller, adjustable power, soldering station, and find it performs much better than most stand alone irons. I think it was $40-$50. For hobby use you can still use solder with lead, unless it's been outlawed in your local.
This post is a work of art. Variations in spelling and grammar are intentional, artistic endeavors that add value to all of mankind.
I use a second-hand Metcal STSS power unit with an MX-500 handpiece and MX-500 cartridges. It cost me about the same as a new Weller unit and is *much* better. They use RF heating; the tip heats up in seconds and the temp. control is very accurate.
STSS units often come up on Ebay - I bought a second one for £70 as a spare.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
Paul Baker
Paul Baker
Leon
I had never heard of ChipQuik before. That's pretty slick stuff! It must be some kind of bismuth alloy to have such a low melting point.
Leon
http://rotometals.3dcartstores.com/Low-Melting-Point-Alloys_c_16.html
which shape of tip do you use, pencil, chisel, chisel at a 45 degree angle?
and do those "tweezer" style irons work? (I assume they're for the little boxy shaped resistors, etc?)
thanks much for the replies,
Howard in Florida - squinting at these little gizmo's even through the magnifier!
It makes it easy to do the solderball drag technique for SMT work. (this is a Xytronic tip #44-415443 from HowardElectronics.com)
Paul Baker
isn't 3 mm a tad wide for those dinky little leads?
thanks for the prompt response, btw.
- H
Post Edited (CounterRotatingProps) : 10/22/2008 12:12:56 AM GMT
Because you are dragging it, it's ok for the tip to touch more than one pin simultaneously.
Paul Baker
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
