Help with BS2 parts...Dual NPN & Single PNP
hmlittle59
Hello to all,
I'm looking to buy these parts from Mouser, Jameco, or Digikey but they don't have them in stock. Can anyone please advise. I called Tech. Support and got some part numbers but no one seems to have them in stock or know of them. Best they could do is get me a Quote.
Thanks again for any help
I HAVE LEARN SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
hmlittle59
Hello Again,
I meant to hit View instead of submit.....
The 2 parts from the BS2 are:
1) Dual NPN Tans. Pack (10k res. 2n3904)
2) Single PNP Tans. Pack (10k res. 2n3906)
where to buy???
thanks again
hmlittle59
The FindChips search engine is what I use: http://www.findchips.com/
Bruce Bates
When all else fails, try inserting a new battery.
'Still some PropSTICK Kit bare PCBs left!
hmlittle59
hmlittle59
XN1211 dual digital NPN, 10k-10k in SOT23
UN2111 single digital PNP, 10k-10k in SOT23
available from Digikey. There are several companies that make these, also called transistor arrays or digital transistors. Digikey also carries the Rohm brand.
Tracy Allen
www.emesystems.com
Chris Savage
Parallax Engineering
Thanks for the Parts help Tracy and I will try the pencil icon next time, thanks
Thanks for all the help
hmlittle59
If you are attempting a DIY repair of a BasicStamp, you might try Parallax's customer service. BTW, they do repair BasicStamps if the damage is not too severe.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
hmlittle59, I don't know why the tech at Digikey gave misleading info, but sometimes you have to have the exact terminology down. If you ask for a dual 2N3904 with 10k resistors they might get thrown off, but with "digital transistor" typed in the Digikey search box, the vista opens up. There lots of different configurations of digital transistor available with different built-in resistors. The characteristics of the transistors themselves are indeed similar to the general purpose 2N3904 or 2N3906.
Tracy Allen
www.emesystems.com
Tracy Allen
www.emesystems.com
I've done 3 spines on my board with through hole components and a "BS2" in a socket(works great). Now I wanted to move up to SMT components and have purchased all but a few components for my first spine. I first laid out the board with ExpressPCB but thought that I needed to switch software packages. Someone from this forum suggested DipTrace and I love it. Now I'm doing the board with DipTrace software and need to relearn all the SMT symbols to make sure I'm ordering the correct parts. I've found (WWW.intersil.com/design/package) and printed it out. Any way, thanks for all the help and insight. I'll be ordering the parts suggested now.
thanks again...it's late and I need to get to ordering and parts match up(sizes) in my design.
thanks again for all the help
hmlittle59
If you're doing a layout from scratch and have the room, by all means use the larger (SOT23-size) transistors. They're much easier to see and to solder than the super teeny SOT416s!
I've ordered the parts(Digikey) and it turns out that the pinout of their components is different, that kind of confused me. Had to get help from there tech. to ensure that I knew what I was ordering. I'll just have to lay it out according to that drawing.
The resistor pins enter and exit from the same side of the body of the chip....instead.... of enter on one side and exit on the other side of the body as in the BS2 Schematic drawing...(Across the Base)...Hope this will not be a problem(noise,feed back..etc.)
hmlittle59
Don't go by the BS2 schematic. There's an error in the pinout for the dual NPN module. Logically, it's okay (i.e. bases connect to SIN and ATN, both emitters to Vss, collectors pulled up and connected to the PIC). It's just the pinout that's wrong.
It is also worth mentioning, if you are building your own BS2, to watch the pinout of the PIC16F57. The pinout on the DIP and SOIC packages are different from the pinout on the SSOP package. It is the SSOP that is used on the BS2 module. The same thing is true of the 28 pin SX chip that is found on the BS2e and BS2sx. The DIP and SSOP pinouts are different.
Tracy Allen
www.emesystems.com
Tracy Allen
www.emesystems.com
The parts from digikey should be here today and they are the six pin. I'm doing my own board layout and wanted to use the same board for the BS2 and BS2e but noticed the on-board 5v reg. part is different. So I may just do the "e" version and up date the code with more options.
I'm not quite clear on the Parallax schematic layout error and the difference between 5 or 6 pin transistor. The "Dual" from Digikey is laid out differently then the Parallax Schematic, will that just complicate it even more with the pin out being wrong? Is it documented some place on this forum so I can print it out?
1) Who has the correct pin lay out?
2) Can I just use the Digikey part and be ok(with the correct pin out)?
3) Why is the BS2 board different then the "e" version (5v reg.)
I'm getting cross Eyed again on try to figure this out...thanks guys for all the help
hmlittle59
I got my parts in today and I guess I'm still confused on how to route the traces, I have no documentations only the BS2 printout from Parallax. I have no written info on how the "Dual" transistor should be connected. I'll see if I can get it from Parallax. Thanks for the info.
1) So I'm clear, the BS2 schematic from Parallax is wrong?
thanks
hmlittle59
I'll start on that part tomorrow. I may need to PM you if I draw a blank over night.
thanks again
hmlittle59
