OSX/Win32/Linux Spin Compiler-0.15.3 - Page 2 — Parallax Forums
2456
  • BradCBradC Posts: 2,601
    edited 2008-10-01 08:19
    stevenmess2004 said...
    Looks cool,
    I get the following when I try to compile RGW_JTC_TinyBasic_010.spin from the hydra cd
    steven-messengers-computer:~ stevenmessenger$ /Users/stevenmessenger/Downloads/bstc.osx -l /Users/stevenmessenger/Documents/Projects/Propeller/Hydra/demos/JT_Cook/T_Basic_Mod_08_06_07/RGW_JTC_TinyBasic_010.spin
    Brads SpinTool Compiler v0.02 - Copyright 2008, All rights reserved
    Compiled for i386 Darwin at 12:04:01 on 2008/09/30
    Loading Object RGW_JTC_TinyBasic_010
    Loading Object RGW_JTC_HTBasic_Support_010.spin
    Loading Object RGW_keyboard_iso_010.spin
    Loading Object RGW_HTBasic_Constants_010.spin
    Loading Object JTC_char_display_001.spin
    Loading Object rem_tv_014.spin
    Loading Object JTC_char_engine_001.spin
    Math Stack Underflow!
    And then it doesn't do anything and doesn't return to the command line.
    Looks like a parse error in RGW_HTBasic_Constants_010.spin. Any chance of a copy of the source?
    Pull my finger!
    edited 2008-10-01 12:28
    New version 0.03 (See top post)
    New spin instruction for those getting into the guts of things
    BYTECODE()
    It lets you insert raw spin bytecodes directly into the method. Can be used pretty much anywhere... see below for an example
    Spin Block ABCDE with 0 Parameters and 2 Extra Stack Longs. Method 1
    PUB ABCDE | X2, X3
    13                              X2 := 1
    Addr : 0038:             36  : Constant 2 $00000001
    Addr : 0039:             65  : Variable Operation Local Offset - 1 Write
    14                              bytecode($36, $65)
    Addr : 003A:             36  : Constant 2 $00000001
    Addr : 003B:             65  : Variable Operation Local Offset - 1 Write
    15                              X3 := 3 + bytecode($36) / 5
    Addr : 003C:          37 21  : Constant Mask Y=33 Decrement 00000003
    Addr : 003E:             36  : Constant 2 $00000001
    Addr : 003F:          38 05  : Constant 1 Bytes - 05
    Addr : 0041:             F6  : Math Op /
    Addr : 0042:             EC  : Math Op +
    Addr : 0043:             69  : Variable Operation Local Offset - 2 Write
    Addr : 0044:             32  : Return
    Pull my finger!
    edited 2008-10-02 02:13
    Just what I need to brute test my Interpreter - Thanks heaps smile.gifsmile.gif
    Post Edited (Cluso99) : 10/12/2008 12:41:18 PM GMT
  • rjo_rjo_ Posts: 1,825
    edited 2008-10-13 03:17
    Hi Brad,
    You are correct. bstc is exactly what I would want.
    Finally found this thread thanks to Cluso99's thread...
    When you suggested bstc... I thought you were talking about c language sources:O)
    bstc finds my prop and runs as advertised.
    I cannot get option 2 to work under OS X 10.4.1.1 on a G5...? I assume that I can just compile and then load it using the loader.
    Thanks again
    Rich
    edited 2008-10-13 03:28
    rjo_ said...
    Hi Brad,
    Option 2? As in Load EEProm and Run ?
    If not then I'll get it fixed. If bst works for you and bstc does not then I've done something silly as they both share the same compiler/loader code.
    Does -p0 or -p1 work for you ?
    Brad
    Pull my finger!
    edited 2008-10-13 12:59
    that would be silly[noparse]:)[/noparse] I looked right at it and couldn't figure out why there was no -.
    works fine.
    for any other idiots out there... there is a line in the instructions that looks like this:
    -p[noparse][[/noparse]012] - Program Chip on device (-d),
    which seems to say use -p012 -d to Program chip on a particular device d...
    that's not what it says... it says (for example) use -p2 to compile and load EEProm[noparse]:)[/noparse]
    So, your final command line instruction should look something like this
    /Parallax/bstc.osx -p2 /Parallax/simpleterminal.spin
    Post Edited (rjo_) : 10/13/2008 1:09:07 PM GMT
    edited 2008-10-21 04:12
    Version 0.06 released - See top post.
    What happened to 0.04 & 0.05? They were internal fixes and releases incorporated into bst.
    Major changes?
    - Assembly listing
    - Improved Propeller detection / download
    - Bugfixes
    Pull my finger!
    edited 2008-10-21 05:53
    Fixed downloading
    Pull my finger!
    Post Edited (BradC) : 10/21/2008 8:50:53 AM GMT
  • SapiehaSapieha Posts: 2,964
    edited 2008-10-21 16:40
    Hi BradC.
    Have loaded and tested BSTC 07 and have problem to compile.
    ERROR.
    H:\Arbets\_Div Spin Code\-_ HardWare\HardWare\Homespun Spin compiler\BSTC>bstc -
    l -o FullDuplexSerial4in1.spin FullDuplexSerial4in1.spin
    Brads SpinTool Compiler v0.07 - Copyright 2008, All rights reserved
    Compiled for i386 Win32 at 13:20:24 on 2008/10/21
    Loading Object FullDuplexSerial4in1
    An unhandled exception occurred at $0041F40B :
    EStringListError : List index (277) out of bounds
    $0041F40B
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
    edited 2008-10-21 17:33
    Sapieha said...
    Hi BradC.
    ERROR.
    $0041F40B
    Can you send me a copy of that spin file please?
    I *think* I know where the problem is, but I need to reproduce it precisely to check.
    Pull my finger!
    edited 2008-10-21 19:44
    Hi BradC.
    It is file that produced this error.
    Sapieha
    edited 2008-10-21 20:38
    I'm curious about the level of optimization done by the current compiler. I have lots of code where objects have methods to retrieve internal variables, like this:
    PUB GetX
    return xValue
    And those objects are used like this:
    OBJ
    SO : "SomeObject.spin"
    PUB Function | x, y
    x := SO.GetX
    Does the current SPIN compiler (or this one by BradC) do anything to optimize this case? Does the compiler actually call the 'GetX' method to get the variable? Given the global knowledge the compiler has, this could become a direct memory location access. Does the compiler make any attempt at 'inlining' like this?
    If the compiler doesn't optimize this case, is it possible to directly access VAR members of an object instead of using access functions?
    Jason
  • evanhevanh Posts: 17,077
    edited 2008-10-21 20:59
    Umm, It's wrong to call bst a compiler. There is no reconstructing of the program taking place.
    Tokeniser is prolly the best name.
    edited 2008-10-22 04:10
    JasonDorie said...
    PUB GetX
    return xValue
    OBJ
    PUB Function | x, y
    x := SO.GetX
    Jason
    The answer to both of those is no. Here is why.
    As objects can be assigned to arrays, there is no certain way of knowing which objects variable segment you are going to access when you do an object call.
    It *possibly* could be done for your case where the object is a single, but then the compiler has no real understanding of the contents of the GetX call. It could be far more than just a "return X" and therefore would not be possible to optimise away.
    Additionally, until the final object distill and link is done, each object is a completely stand alone bit of memory, so the compiler does not know where the variables for other objects are being placed until the very last moment. You can access the var members of an object quite easily however by passing a reference to the variables address using the @ operator.
    The only "optimisation" bst/bstc does at the moment is unused method removal, constant folding and some minor size/speed optimisations to do with addresses and constants. I've not pushed it any further at this time, although dead code removal and branch optimisation are things I'm thinking about (In addition to some tricks to compact the data segment used by STRING() at the end of the object).
    Pull my finger!
    edited 2008-10-22 04:11
    Sapieha said...
    Hi BradC.
    Thanks very much Sapieha, that allowed me to pin it down. I'll have a fix today. In the meantime if you don't enable the listfile output it won't crash.
    Pull my finger!
  • mparkmpark Posts: 1,336
    edited 2008-10-22 06:26
    evanh said...
    Umm, no, it's definitely a compiler. Tokenizing is just a small part of what it does.
    edited 2008-10-22 09:38
    mpark said...
    Example?
    Ok, 0.08 up with the bugfix for the fault Sapieha found.
    This would only manifset itself if
    A) listfile generation was enabled
    B) the last line of the source file was source code
    C) the last line of the source file was not terminated with a CR/LF or combination of
    Not a required upgrade unless you hit this one specifically.
    Pull my finger!
    edited 2008-10-22 09:42
    evanh said...
    mpark said...
    Example?
    I fully agree with mpark here in that spin syntax does not map directly to spin bytecode. There are a number of cases which require you to generate bytecode in a context sensitive fashion.
    It's a combination of a compiler/assembler/linker really.
    Pull my finger!
    edited 2008-10-22 09:50
    Conditional tokenising or macroing?
    edited 2008-10-22 09:52
    evanh said...
    conditional tokenising
    Pull my finger!
    edited 2008-10-22 11:15
    Hi BradC.
    I have mentioned on Homespun thread alternate HEX code listing for PASM.
    It is posible for You to have that listing?
    Sapieha
    edited 2008-10-22 11:34
    BradC said...
    Ok, I'll put it this way. Since the one thing bst doesn't do is compile code, calling it a compiler is wrong.
  • AribaAriba Posts: 2,695
    edited 2008-10-22 12:06
    @evanh
    From Wikipedia:
    "A compiler is a computer program (or set of programs) that translates text written in a computer language (the source language) into another computer language (the target language)...."
    bstc compiles a Spin source code to a Spin byte code, and includes also a Propeller Assembler.
    @BradC
    I'm really impressed of your work (and also of mpark's work, but I like it more if no .NET framework is needed).
    With the DAT (assembly) listing your bstc is now perfect suited for a source code debugger (like PASD, but also for Spin).
    Andy
    edited 2008-10-22 12:32
    @Ariba: I have done a Pasm and Spin debugger (zero footprint) and the output listings of both Brad and Michael's compilers are great to do a source code debugger along the lines of your PASD.
    edited 2008-10-22 13:59
    Evanh, maybe you should tell us what you think compiling is, since you seem to be using a definition different from the generally accepted one.
    edited 2008-10-22 19:27
    Ariba said...
    From Wikipedia:
    The key word is "another".
    The Spin interpreter is the same language as the Spin source. The Cog machine code is the same language as it's Assembly. There is no other computer language to convert to.
    edited 2008-10-22 19:57
    evanh
    The bytecode is not a direct representation of the Spin source code. The bytecode interpreter is like a virtual CPU (or generaly a virtual machine). If you look at a listing, made with bstc, then you will see, that a source command is translated to several bytecode instructions, which together build the Spin command. And an other combination of the same bytecodes build then another command.
    So the bytecodes are low level instructions, comparable with an assembly language, but shurely better fitted to the Spin language.
    I also do not agree with the statement (not from evanh), that Spin is an Interpreter language, and the interpreter fits in the 496 cog ram longs. Spin is a compiler language, that uses an intermediate bytecode, which is executed by a virtual machine in a cog. This is near to the Java approach.
    Andy
    edited 2008-10-22 20:39
    Ok, good nudge. [noparse]:)[/noparse] I should have looked before.
    I grabbed a copy of bstc and compiled the example (Ch3-Ex02)-Output.spin. It's very small with a loop and waitcnt. Both commands generated suitably complex code to be called another language. Eg: There was four separate operations to execute the waitcnt: stack Delay, stack CNT, add, waitcnt.
    Agreed. Spin is indeed compiled to bytecode. My mistake.
    edited 2008-10-22 20:43
    I ASSumed ... and now just a tad embarrassed.
