Running a ProtoBoard from 12V Battery
For the project I'm working on, I need to run a Protoboard off a 12 volt battery. Looking around in old threads I found something that said you can just do it, but that the 5V regulator would need a heat sink. I tried that - the heat sink quickly go too hot to touch and I think I fried the whole board.
So I'm looking for a better solution. My current thought is to use a Meanwell 15W DC-DC converter (Jameco part number 155716) which would give me 5v at 3 amps. Does this sound like a good way to go, or is there some better way to run on 12 volts?
If I do use the DC-DC converter, should I leave the LM1086-5.0 mounted, and run through it, or should I strip it off and use the 5v from the converter directly?
Paul Baker
Another thing you can do is add another regulator (LM7808 for example) in between the 12v supply and the input to the protoboard. We've tried that before too. Effectively it just gives you another regulator to help dissipate the wasted energy.
If your 5V regulator is getting way too hot with a heat sink, you can usually fix that with a better heat sink (and by getting the regulator up off the PCB).
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
