754410 driver to DC motor — Parallax Forums
enkeienkei Posts: 23
edited 2008-10-02 20:59 in General Discussion
i am using 4 dc motors and i want to put the .01uF capacitors to eliminate noise how do i have to put the capacitor from Y to cap to motor on each one of them or on the + and - of the motor but there is a y in the negative to go reverse already.
sorry about the drawing im just trying to draw it fast.
    edited 2008-09-29 13:09
    Each motor needs 3 non-polarized caps for the traditional delta filter. See sketch, one cap bridges two motor terminals (+ and·-·as marked) and each terminal has another cap going to the metal motor case, just scuff the surface with sandpaper and solder it quickly with a BIG (200 watts or more) Weller soldering iron.
    175 x 175 - 7K
    edited 2008-09-29 15:10
    This thread is being moved from the BASIC Stamp Forum to the Sandbox Forum as it is off topic. This forum is for BASIC Stamp discussion only.
    Chris Savage
    Parallax Engineering
  • enkeienkei Posts: 23
    edited 2008-09-30 04:55
    can u draw how will you connect 4 dc motors with the caps and the sn754410
    Check out http://www.kronosrobotics.com/an101/DAN101.shtml
    but you'll need to add the 3 caps per motor per my previous diagram.
