can I run the SX Tech board without the Key?
I have an SX tech board and the serial SX-Key (ref F) connected via a USB converter (rev
, and am using SX-Key v.3.2.3 software.
If I download a program with the key connected, everything works fine, but if I disconnect the Key, the SX won't run on its own (the Tech board is still powered by the 7.5v adaptor).· Do I need some additional circuitry?· I didn't have a resonator plugged in to the socket.
I was hoping to be able to program multiple SX's with the same Key (one at a time, of course.)
Joe
Joe
-Paul
I'm not sure about the oscillator settings--I copied the first part of the program from a tutorial.
Using the SX Key Assembler, I assembled a program and then, with the·Key installed,·clicked Program.
The popup says the program downloaded successfully, but the program·is not running on the Tech board while the key is installed.
Then when I remove the key, the program runs once (or briefly).· If I press the reset button on the Tech board, the program no longer runs.
Reinserting and removing the key (without clicking Program or any other software activity) causes the program to run once more. It seems it is the removal of the key that causes the program to run.
In fact, I'm not even sure the program is still running with the key removed--the program ends with an input-output loop, but the program does not respond to changed input--the outputs at the time of key removal are "frozen".
I thought pressing RESET on the board would re-run the program, as it does in RUN mode, but in PROGRAM mode, it is behaving as if removing the Key is·running it--and only briefly.· The program ends with a loop, but the loop is inactive once the key is removed.· Is there some code or external wiring I need to rerun the (presumably) stored SX program without using the Key?
Joe
You didn't indicate if you put the resonator in after removing the SX-Key and then hitting the reset button. Without a resonator or other clock source, how do you expect the SX to run? It's like a car with an empty gas tank - looks pretty but just sits there.
PeterM
But you can test to see *where* things are breaking down -- I would try changing your freq and osc directives to use the internal RC oscillator. (4_000_000 and OSC4MHZ). Then see if the program runs without the key connected and without a resonator/crystal in place.
If it works, then you know you've got a freq/resonator/key conflict... try it again with 50_000_000 and OSCHS2, then run again without the key connected and *with* a 50mhz resonator in place. Also, do you have a 10k or so resistor connected beween osc1 and osc2 (the resistor is generally a good idea to startup the resonator properly -- see the SX datasheet. The big ceramic DIP resonators already have the caps· inside them, small surface mount resonators do not).
in your program code, you have configured the SX to generate a 50 MHz system clock from an external crystal or ceramic resonator connected to the OSC1 and OSC2 pins.
With the SX-Key attached to the SX Tech board, the SX-Key will first program the SX28 on the SX Tech board, when you select "Run - Run" from the SX-Key IDE (or press Ctrl-R instead), and it then will supply the 50 MHz clock to the SX Tech board.
With the SX-Key removed, the SX28 on the SX Tech board needs a crystal or resonator to be attached to the OSC1/OSC2 pins instead, for generating the clock signal. In your case, you should plug the 50 MHz resonator (the blue 3-legged device that came with the SXTech Board, with a print reading like 50.00 on it) into the 3-pole socket on the SX Tech board.
Greetings from Germany,
G
