6.78 MHz crystal ?
Hello,
I'm toying around with a concept for short-range (< 50m) propeller to propeller communication using the 13.56 MHz ISM band.· This concept was inspired by Phil Pilgrim's AM radio.· Since you can't use a 13.56 MHz·crystal to drive the Prop, I've been looking for a 6.78 MHz crystal.· Anybody know where I can find one (in the US)?· It appears Digikey only has 13.56 MHz crystals.
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
- Bjarne Stroustrup
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
This place used to be down the street from me when I lived in Oklahoma City... http://www.icmfg.com/
I have dealt with them before for some custom precision crystals we had them make.· They seemed pretty reasonable with their pricing and turn around.
Beau Schwabe
IC Layout Engineer
- Bjarne Stroustrup
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
That said, you can order programmable oscillators from DigiKey that they will program to any frequency you want. 54.24 MHz (13.56 x 4) might be a good choice for this app.
'Still some PropSTICK Kit bare PCBs left!
Post Edited (Phil Pilgrim (PhiPi)) : 9/26/2008 5:41:58 PM GMT
Reality may be that you can, but if you want to stick within what the datasheet says then no.
I and others have had some success with 7MHz+ and PLL16x plus 14MHz+ and PLL8x ...
propeller.wikispaces.com/Oscillator
- Bjarne Stroustrup
- Bjarne Stroustrup
Thanks for your suggestions.
- Bjarne Stroustrup
Leon
Read this thread.
http://forums.parallax.com/forums/default.aspx?f=25&m=215415
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
My video driver seem to work fine and it reduced the necessary cogs from 5 to 3 to display my sprites...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Did you get anywhere with this?
Ken
did someone use the LTC6904 ?. I'm trying to interface to it but I do not get any ACK bit and most of the time it just ignores to programming words. I'm using a 100kHz I2C clock. Any ideas ?
thanks
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
pPropellerSim - A propeller simulator for ASM development sourceforge.net/projects/ppropellersim
Like if I get a 1.2345Mhz or a 5.4321Mhz, can I use it? Will the serial communication style works correctly?
When you try to push the prop to 100Mhz (6.25Mhzx16), what's the impact? I will become hot?
Can we put a heat disipator on it and push it at 120Mhz?
Just asking. Since I can't change the crystal on the PPDB [noparse];)[/noparse]
JM
Yes, you can use whatever crystal you want as long as it meets the frequency and capacitance and so on specified in the datasheet. Crystals up to 15 MHz have been reported to work.
The impact ? ... current needs go up some 25 %, instruction cycle decreases 25 % to 40 ns (processing power goes up to 25 MIPS per core). Decoupling is always important and at higher frequencies even more so, use a 10 uF tantalum, a 1uF and a 10 nF for each VDD pin. That should suffice.
I cannot comment on the possibility of you becoming hot, but the propeller dissipates little power and thus it was reported not to generate much heat.
Even at 120 MHz it does not need a heat sink. 120 MHz is really pushing it.
Leon Heller
Hahaha! I did not figured I wrote that! [noparse];)[/noparse]
Thanks for your reply. I will try to play a little with the Crystal on my next Prop to see if I can have it working fine with another Prop using a different Crystal.
What's the max frequency ever tried on propeller?
JM
Message Edité (jmspaggi) : 5/1/2010 1:47:49 PM GMT
I will do some testing to see what's the result.
When you are talking about "decoupling", are you talking about the same thing Ale said?
Or is there anything else I need to do for this decoupling? Also, there is 3 capacitors here. Should I put all of them in series between the Prop and Vdd? Or in parallele? Or just one of them?
Also, if I back Crystals, except the frequency, is there any other caracteristic I should take care of?
JM
What do you mean "back Crystals"??
Where can I found more information for that?
Where should I place those 2 ones?
JM
Note: I did not have the time to make the changes you sent me. I'll add them as soon as I can.
Ale
Edit: Decoupling capacitors should be placed as close to the power pins as possible ( < 8 mm away and with thick traces, like 0.4 mm or thicker). Larger caps like 10 uF do not need to be that close (a few cm apart is okay).
