MSRS Test program TestSpeakerLedsServos.bs2
When I run this example program (TestSpeakerLedsServos.bs2 ) after the robot moves forward it resets back to the beep and just loops. I cant find a problem in the programming or in the circut it is meant to run with. Any help would be nice.
Thank you
' TestSpeakerLedsServos.bs2
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
DEBUG "Beep!!!...", CR
FREQOUT 4, 3000, 3500
DEBUG "Lights on...", CR
HIGH 15
HIGH 14
PAUSE 2000
DEBUG "Lights off...", CR
LOW 15
LOW 14
DEBUG "Forward...", CR
FOR counter = 1 TO 35
· PULSOUT 13, 850
· PULSOUT 12, 650
· PAUSE 20
NEXT
DEBUG "Rotate left...", CR
· PULSOUT 13, 650
· PULSOUT 12, 650
· PAUSE 20
NEXT
DEBUG "Rotate right...", CR
· PULSOUT 13, 850
· PULSOUT 12, 850
· PAUSE 20
NEXT
DEBUG "Backward...", CR
· PULSOUT 13, 650
· PULSOUT 12, 850
· PAUSE 20
NEXT
DEBUG "Done!", CR
Thank you
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
HIGH 15
HIGH 14
PAUSE 2000
LOW 15
LOW 14
· PULSOUT 13, 850
· PULSOUT 12, 650
· PAUSE 20
NEXT
· PULSOUT 13, 650
· PULSOUT 12, 650
· PAUSE 20
NEXT
· PULSOUT 13, 850
· PULSOUT 12, 850
· PAUSE 20
NEXT
· PULSOUT 13, 650
· PULSOUT 12, 850
· PAUSE 20
NEXT
DEBUG "Done!", CR
Chris Savage
Parallax Engineering
