QT113-D Touch Sensor
I'm looking at using the QT113-D Touch Sensor for a application here and had some questions about it.
First, has anyone here used this sensor in a application before?
Would anyone be able to tell me if there is a limit on how long the sensor wire can be?· I'm looking at having the sensor wire be able 2-3 feet from the actual board/chip.· Would this be ok, or is it going to affect the sensor ablity to function correctly?
thanks for any/all input·
The datasheet for the part goes into more detail on this sort of thing. I would check there first and then follow-up on this thread if you have more questions. I myself haven’t used it that far from the sense plate, so it may be something you have to test.
Chris Savage
Parallax Engineering
I was hoping someone here already had a chance to work with this IC and would be able to give us some insite on how well it works
Thanks!
Keep the wire clear of grounds as well, it is suggested that the wire not be shielded, or have the PCB traces be ground poured near the traces from the chip to the sensor.
I don't use that exact model, but the technology is great between all their chips. Adjust(change) the cap to set the sensitivity.
What about having multiple sensor wires running together (like in a cat 5 cable)? Would/Should the cables be shielded then?
Thank You
I am certain that by adjusting the cap value, you will find some method that works just fine.
(looking at the datasheet for the chip, has a sample circuit)
In adjusting the cap value, would i be able to adjust the resistor as well (to adjust the sensor)?
Would a pot (in place of the resistor) work?
Thoughts?
Thanks!
Maybe i'll look into a adjustable cap for the circuit then...
I'll also look into the Adjacent Key Suppression mode as well. The sensors will be right next to each other (in a row), and i'll have to make sure i don't get any false 'touch'es from the neighbor sensors.
I'll work on the circuit design this weekend and post the design if i get it done... after that will be making it on a breadboard and testing it out!
Cool
Thanks!
