When to use VAR and when to use DAT?
I know it should be easy to understand this but I really can't get it.
If I want a variable reachable from anywhere, is it in VAR och DAT I should put it?
If I want a variable that I can write/read from any cog, where do I put it?
Short question, when to use DAT and when to use VAR?
And yes I have read the manual about VAR and DAT blocks but I think I need some help here.
/Henke
/Henke
VAR long myVar
DAT myVar long 0
Will create a variable 'myVar' which is accessible by the Spin object / main program it is defined in, and any methods of that which are launched to run in separate Cogs.
The difference comes when the variable is in an Spin program which is used as a sub-Object more than once. For VAR, every sub-object will have its own instance of "myVar", for DAT they will each refer to the same variable.
Which you need depends on what you are trying to achieve. If each is counting how many times a signal is received say, they will likely want VAR so each count is independent of the other counts. If they were each updating a total of any signals received a single DAT would do that ( you need to to take care to prevent simultaneous updating from multiple Cogs ).
If cog1 have done something that it needs to send to cog2 it can write that to VAR long cog1Var and cog2 can read it from there, right?
And if I need to keep track of number of instances of my new object I use the DAT section, right?
/Henke
Either VAR or DAT can be used to pass data between cogs if those cogs are launched in the same object ...
Both 'a' and 'b' have access to 'countervar' and 'counterdat', so their values will go up twice as fast as when only one or the other cogs were running.
1. DAT variable: global to all instances of an object and all its methods. Can take on any initial value declared with a LONG, WORD, or BYTE pseudo-op.
2. VAR variable: local to each instance of an object; global to all its methods. Gets initialized to zero.
3. Method variable: local to the method it's declared in. Initial value is undefined.
'Still some PropSTICK Kit bare PCBs left!
Is there any other good reason to use DAT vs VAR besides that DAT can predefine a variable and store tables etc?
/Henke
DAT variables, as Hippy explained above, can be used to count instantiations of an object. They can also be used for communication between separate instances of the same object. These are just two examples that go beyond predefinition and table storage.
/Henke
So when do I use DAT then? (except for tables and predefined variables)
Any rules here or I can use it as I like?
Can I use memory more effective by using DAT och VAR?
/Henke
It's only when you are dealing with sub-objects does how the variables are defined really matter; VAR if you want to have each variable unaffected by the same named variable in another Cog, and DAT if you want all Cogs to use the same single variable.
The best rule is perhaps : Use VAR, except when you specifically need to use DAT.
Once you've gained experience and are more familiar with Spin it should all become a lot clearer. Use VAR by default and when you need to use DAT should become obvious. I would venture that most objects do not need to use variables in DAT.
/Henke
1. Define your variables (VAR or DAT)
2. Define your pointers (longs in DAT placed within 496 longs of the start of your PASM routine)
3. Call an initialization routine in SPIN that sets the pointers to point to the variables, i.e., var_ptr1 := @var1, etc.
4. Start your PASM routine with COGNEW() - your initialized pointers will be loaded into the cog along with your code!
5. After the cog starts, your pointers will be local to the cog only. Subsequent changes to the pointer values in DAT will not be reflected in the cog. They are copies. However, your cog will have read and write access to your variables via the pointers.· Since your variables will never move in memory, your pointers·are not likely to change anyway (see exception below).
6.· If you have multiple instances of an object that has a PASM routine, each instance will have to call that initialization routine to·set the pointers to variables in·its own VAR section before calling COGNEW() to start the PASM cog.· This is the case where the pointers in DAT would actually change.
7.· You can use DAT variables to pass other parameters to your PASM routine as well.·· Just remember that they are copies (passed by value, not by reference).
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
Post Edited (Ken Peterson) : 9/25/2008 1:06:50 PM GMT
"I have always wished that my computer would be as easy to use as my telephone. My wish has come true. I no longer know how to use my telephone."
- Bjarne Stroustrup
I couldn't resist... and my tv, video recorder... even the toaster is going that way :-(
