suggestions for board-to-wire connectors?
Hi everyone!
A lot of my designs involve multiple printed circuit boards each doing something specific. Therefore, a (nonpermanent) way to connect the boards together for signal/data/power is a must.
I'm curious as to what types of connectors you guys used to make these board-to-wire-to-board connections? I'm thinking of using the AMPMODU MTE connectors from Tyco Electronics. They seem like a good choice because they are 0.1" centerline, single-row available, with 2-50 circuits available (although I will not be using a 50 pin connector anytime soon!) and with polarized mating capability. I'm·leaning towards the·right angle polarized single row PCB headers and their corresponding cable receptacles, then crimp my own connectors. I can easily buy them off Mouser.
What do you think? Do you use something different? Tips, suggestions and things to look out for?
Much appreciated!
Post Edited (InSilico) : 9/23/2008 7:28:41 AM GMT
Much appreciated!
'Still some PropSTICK Kit bare PCBs left!
I tend to use right-angle male headers on my circuit boards and female/female cables for interconnect. For crimping the terminals, I've found that a "bead crimping" tool (found in craft stores in the jewelry making department) makes a perfect cripming tool. Be sure to get the smallest size available and make sure it has a two-stage crimping jaw·(see photo below).
The male and female crimp terminals can also be used to make custom jumper wires (M/M, F/F, M/F) in just the lengths you need. Just crimp them to the wire, use a short piece of shrinkwrap tubing to cover the exposed metal part of the terminal and you're ready to go.
Good luck,
Duffer
Post Edited (Duffer) : 9/23/2008 6:18:28 PM GMT
The only reason why I'm not going for the DF11 series is because my (already fabricated) boards use 2.54mm centerlines for the connectors -·a little late to go back now. I'm a stickler·for 0.1" centerlines because it's more familiar to me...
But thanks for taking the time to answer. I would never figured out the kajillion different possible connector configurations I could use.
