Hot-swappable USB connection via PROPPLUG - is it possible?
HI,
I have noticed that if you disconnect and reconnect a USB cable into the PROPPLUG (I actually use the USB2SER still!) that the propeller will reset!
Is it possible to have the propplug behave so that if you disconnect a cable and/or reconnect that the propeller does NOT reset?
The reason I want this is to allow HOT SWAPPABLE feature for my users if I were to use a PROPPLUG circuit/device to allow firmware uploading of standard SERIAL Communications.
I am planning on making my own USB to serial type of "propplug" (that will be part of my main circuit) and would like to know how I could achieve this feature
I only want the prop to reset if I were to upload firmware to it.
Dave M
Dave M
So I would use some kind "SWITCH" so on my products outside panel that would say "allow firmware update"? if its on then firmware can be installed, if its off ( which disable the DTR ) then the user can "HOTSWAP a usb cable while the prop device is ON?
Dave M
mike
Dave m
If customers are using the Prop Plug then they should be able to hot-plug it into the board without causing a reset. The FTDI chip on the Prop Plug causes a reset due to the way devices are detected and enumerated on the bus. Basically the chip is being cycled several times by the USB port, but when you plug it into the board that doesn’t happen. I hope this helps. Take care.
Chris Savage
Parallax Engineering
Actually, you should really unplug the PropPlug when not in use because there are several things that can cause the USB connection to make&break causing a reset. EMI can also cause a reset when the PropPlug is connected.
to Chris & Rayman,
my customers willl not be using a PROPPLUG.
The "PROPLUG" that I will be devising will be part of the "internals" of my prop powered devices, My users will only see a USB port
The only option I will enable my users to have is to connect or reconnect a USB cable, they wont know that a prop plug even exists.
Mike suggested a SWITCH to prevent resetting the prop by disabling the RESET line to the prop, this is probably the easiest/safest option.
thanks
Dave M
