starting and stopping blinking LED's 'blinker2.spin' — Parallax Forums
Rob v.d. bergRob v.d. berg Posts: 89
edited 2008-09-20 08:58 in Propeller 1
Hi,
I'm playing with the Blinker2.spin code. With LED[noparse][[/noparse]NextObject].Start(16, 3_000_000, 0)·the LED is blinking· forever.·It's·working great.
What·is the·best way to add code for stopping and·later starting the blinking LED's on·demand, or·input (switch). In the·"(Ch3-Ex07)-Output" object there is a STOP function,·i don't·understand·how to use. Is this for stopping all the LED's?
Any idea's??
Rob.
{{ Blinker2.spin }}
CON
· _CLKMODE = XTAL1 + PLL16X···· 'Set to ext low-speed crystal, 4x PLL
· _XINFREQ = 5_000_000········ 'Frequency on XIN pin is 5 MHz
· MAXLEDS· = 4················ 'Number of LED objects to use
· Button_1 = 20· ' for·switching LED nr 1, PIN 16
OBJ
· LED[noparse][[/noparse]MAXLEDS] : "(Ch3-Ex07)-Output"
· BS2·· : "BS2_Functions"······ 'create BS2 Object·
PUB Main
· BS2.start (31,30)
{Toggle pins at different rates, simultaneously}
· dira[noparse][[/noparse]16..19]~~······························ 'Set pins to outputs
· LED[noparse][[/noparse]NextObject].Start(16, 3_000_000, 0)····· 'Blink LEDs
· LED[noparse][[/noparse]NextObject].Start(17, 6_000_000, 0)
· LED[noparse][[/noparse]NextObject].Start(18, 9_000_000, 0)
· LED[noparse][[/noparse]NextObject].Start(19, 12_000_000, 0)
· repeat········································ 'Loop endlessly
····if ina[noparse][[/noparse]Button_1] == 0 ' I have add the blue code·
····· LED[noparse][[/noparse]x].Stop······ ·'x·=·1 to 4 is not working
PUB NextObject : Index
{Scan LED objects and return index of next available LED object.
·Scanning continues until one is available.}
· repeat
··· repeat Index from 0 to MAXLEDS-1
····· if not LED[noparse][[/noparse]Index].Active
······· quit
· while Index == MAXLEDS
    edited 2008-09-19 14:20
    hello Rob,
    in the code posted above a variable named "x" is not defined
    you have to define in the VAR-section of your SPIN-File
    to me it's not really clear what you mean with "on demand"
    please make a celar and detailed description what you would like to do
    With the posting above I can't decide which is the best way to do it
    Anyway to make a suggestion of ONE way is the following
    The method NextObject gives back the number of the next free LED-object
    What is easier to understand is if you make the LED-Object-No hardcoded
    ATTENTION !
    arrays are defined with the number of elements her MAXLED = 4
    BUT ! the first element has NOT number 1 it has number 0 !
    so the index runs from 0 to 3 which is 0 to MAXLED - 1
      LED[noparse][[/noparse]0].Start(16, 3_000_000, 0)      'Blink LEDs
      LED(1).Start(17, 6_000_000, 0) ' replace round brackets with square-brackets as in the line above
      LED(2).Start(18, 9_000_000, 0) 'square-brackets are eaten up by the forum software
      LED(3).Start(19, 12_000_000, 0)
      'now you can start it as above
      'and stop it with the index-number
      'stop LED 17
      LED(1).Stop
    best regards
    Stefan
  • Rob v.d. bergRob v.d. berg Posts: 89
    edited 2008-09-19 20:44
    hello stefan,
    thanks,·yes i know about the array. I want to stop and start·a LED by a switch like the code below. This·is working well.·Is this the smallest code ?, maybe the test <if not LED[noparse][[/noparse]0].Active> can be implemented in the object?
    ··· if ina[noparse][[/noparse]Button_1] == 0·
    ····· LED[noparse][[/noparse]0].Stop
    ··· else··········
    ····· if not LED[noparse][[/noparse]0].Active
    ······· LED[noparse][[/noparse]0].Start(16, 25_000_000, 0)
    Rob
    edited 2008-09-19 21:30
    hello Rob,
    I'm again not sure what you mean exactly
    implemented in WHICH object ?
    Do you mean implementing the test <if not LED[noparse][[/noparse]0].Active> in the "(Ch3-Ex07)-Output"-object ?
    best regards
    Stefan
    edited 2008-09-20 07:25
    Stefan,
    Yes, so you·don't·need to do that in·your main program.
    Rob.
    edited 2008-09-20 08:51
    Hello rob,
    you can do that
    but how does the object know WHEN to do it
    other than the MAIN-program tells the object to do so
    If it is just inside the "(Ch3-Ex07)-Output"-object it is there but it has to be called
    from outside the object
    best regards
    Stefan
    Hello Stefan,
    Your are right, it's clear for me how it's works.
    Rob
