Low Power Regulator
I would like to modify the SX28 Proto Board (Parallax 45302) to utilize a low quiescent current voltage regulator (TPS76850: 5V 1A) to provide for battery power operation for a project to construct a sensor that would report water levels using PING))) via Bluetooth (eb501) from our cisterns outside to a receiver inside the house.
I wonder if anyone has suggestions or advice about things to watch out for associated with this modification.
marshall hall edgell
You may need a small (0.1uF) ceramic capacitor on the input (in addition to the electrolytic) and a small (1uF) low ESR (1 Ohm) Tantalum capacitor on the output of the regulator. See the datasheet for details.
Note that there's a power-on LED that you'll want to remove or disable because of its power consumption.
Post Edited (Mike Green) : 9/19/2008 3:03:19 PM GMT
The TPS76850 spec sheet suggests using 0.1 uF on the input as you suggest but does say larger capacitors like that on the proto board are fine. The spec sheet suggests 10 uF for the output. However, the spec sheet says that larger capacitors like the 47 uF on the ProtoBoard can be used at the output as long as the equivalent series resistance is less than 1.5 ohm. I have no idea how to assess what the equivalent series is since I do not know what that means. Is this the equivalent resistance of the capacitor?
marshall
marshall
