DS1620 and One-Shot Mode — Parallax Forums
Shawn LoweShawn Lowe Posts: 635
edited 2008-09-18 22:08 in BASIC Stamp
Hello everyone-
This question is primarily directed for Tracy Allen, but perhaps others can chime in and answer. I am working with a DS1620 and want to put it into One-Shot mode for a higher accuracy from the chip. On EME's website, Tracy mentions:
Also, the first time you send the $03 command to the stamp, you have to cycle the power to the DS1620 off, and then on again before the change takes effect. (IMPORTANT. I learned that last little tidbit after some hard head scratching!)
I have seen a program in StampWorks by Jon Williams that also sets the Mode into One-Shot, but he doesn't cycle power. In addition, there is nothing in the Datasheet to indicate a power down is required.
Can anyone confim a powerdown is required?
Shawn Lowe
When all else fails.....procrastinate!
    edited 2008-09-18 17:25
    Shawn,
    Running the code and wiring up the experiment would probably answer that question. [noparse];)[/noparse]
    Chris Savage
    Parallax Engineering
    edited 2008-09-18 17:47
    Hi Shawn,
    I wrote those observations quite a while ago and haven't had occasion to retest it in the interim. Like Chris says, you can test it for yourself and please report back. I might have gotten it wrong, or Dallas might have changed the operation.
    One more comment is that since I wrote that page, Dallas Semi has revised the way DS1620 handles the counts remaining registers. Those are used to extend the resolution past 9 bits. It used to be that it returned a one part in 128 value, but they changed it to one part in 16. That does not alter the algorithms needed to get at the higher resolution, though.
    Tracy Allen
    www.emesystems.com
    edited 2008-09-18 19:12
    Tracy reminded me…Dallas did make a change to the DS1620 at some point. I can’t remember the exact details, but there was a change.
    [noparse][[/noparse]Edit] - It seems at least one change was to increase the supply voltage range.· Sorry I can't find more info, so definitely post your results here.
    Chris Savage
    Post Edited (Chris Savage (Parallax)) : 9/18/2008 7:25:59 PM GMT
    edited 2008-09-18 19:58
    [noparse]:)[/noparse]
    I certainly will report back tonight.
    Thanks Tracy & all
    Shawn Lowe
    The Changes made to the DS1620 were in relation to the high resolution temperature mode...
    Taken from this thread... http://forums.parallax.com/showthread.php?p=606317
    Note: The DS1620 RevD implemented a proprietary temperature sensing architecture using dual slope convergence method to determine temperature.
          The DS1620 RevE implements a commonly used bandgap reference with sigma-delta ADC approach to determine temperature.
          Attached is a file I received directly from Dallas Semiconductor/Maxim noting the difference between RevD and RevE version of the DS1620
    Attached file·-> http://forums.parallax.com/attachment.php?attachmentid=44280
    Here is another thread that might be helpful...· http://forums.parallax.com/showthread.php?p=608042
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 9/18/2008 10:19:24 PM GMT
