Mounting a Key to a servo
Hi,
I've been talking to a few metal workshops about mounting a metal key to a servo motor.
The operation is simple, the servo is supposed to turn the key to lock or unlock.
But most of them has declined to take up the job, saying it is too difficult.
They can't mill a metal cap that fits the servo's plastic head securely ( without slipping off because the screw is not used ).
The key is supposed to be welded to this metal cap.
Any ideas out there would be greatly appreciated.
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
Thanks for the idea.
Another problem.
It seems that they can't easily mill out the grooves from the inside of the metal cap b'cos it is so small.
How now?
www.fd.com.my
www.mercedes.com.my
'Still some PropSTICK Kit bare PCBs left!
Is this a key, as in a door key? If so, is it a house key or is it something smaller, like a cabinet key?
The reason I'm asking is since you a leaving the key in the lock, security from one sode of the door isn't a problem. Possibly this is a double keyed lock and you are going to turn the key from the inside to open it.
So, what are your thoughts behind why you selected a key as the solution? I use to do locksmithing and though I could offer some help solving the problem.
Dan
Now you just need a skeleton key for it and you’ll be all set.
Chris Savage
Parallax Engineering
Nice job Phil and thanks.· I've copied the key geometry from your inclosed photo. I'll be at your home later tonight to steal everything you own. Remember, no good deed goes unpunished.
Duffer
LOL! Good luck with that. Assuming you could even make it past my attack cat, you'd discover that the key (which came out of a junk drawer) won't fit!
¡Lo siento mucho!
You are a genius!
I didn't quite understand what you were saying until I saw the photo.
Do you keep separate labs for electronics and mechanical?
Where you get the small round horn? (why they call it a horn?)
Parallax didn't give me any extra horns apart from the already fitted cross type which is too bulky.
But the truth is, I had hoped to minimize the mounting distance required as the casing would have to be bulky if the servo stands too tall from the door.
Nevertheless it is a good start.
Thanks again.
www.fd.com.my
www.mercedes.com.my
Development, bookkeeping, and shipping are in one room; mechanical, soldering, inventory, assembly, and packaging in another.
The horn came with the servo, but it may not have come from Parallax. Any horn with a Futaba spline should work, though, if you have a Parallax servo. Your local hobby shop probably has them. You can also cut down the large cross types with a pair of nippers. I do that all the time, and they're nearly as sturdy as the disk type.
One thing to watch out for: if you unlock your lock all the way, you may have trouble locking it again with the servo. This is because the lock pins sometimes catch on the edge of the tumbler holes. It's something we, as humans, deal with all the time without thinking by jiggling the key a little. If you can retract the bolt far enough to open whatever you're opening without turning the key far enough that it could be extracted, I think you'll have a lot better luck.
I suppose you could cut off the round head part of the key, and solder it to a piece that attaches to the horn. You could also use a smaller servo like they use in model helicopters.
